Refreshing URL as variable?
Fri Jul 28, 2017 5:36 am
pocster offline
Hey all,
I've searched around and can't see how this would be done.
I have a control page with a refreshing camera image ; I wish it to alternate between 2 different cameras (say staying on each for a few seconds; then looping back).
So I have for the dynamic URL :
http://user:password@127.0.0.1:8000/++i ... height=180
If the URL could come from a variable (rather than hard coded) I *assume* I could write a schedule that simply populates this variable with any camera/stream I wish and just cycle around.
Seems a nice simple solution; but can't see how/if the control pages allow that.
Any ideas?
Ta
Fri Jul 28, 2017 6:01 am
pocster offline
Re: Refreshing URL as variable?
Looking through all similar posts this seems like a common request.
Is the only way to somehow have a fixed URL to a xxx.jpg then have a script of some sort rename the camera file name to xxx.jpg each time
That the best and only method??
Fri Jul 28, 2017 7:34 am
ckeyes888 offline
+1. Been wanting that a very long time.
Carl
Fri Jul 28, 2017 7:43 am
Did you try putting a substitution string (%%v:XXXXXXXX%%) in the URL field?
Fri Jul 28, 2017 8:03 am
Different Computers offline
Commenting here because if substitution strings work in URLs that would be very exciting.
Also, to the OP: Have you looked at the Security Camera plugin? It can manipulate serving of images that are resident as a file, rather than coming from a camera. Perhaps a bit of overkill for what you're looking to do, but I bet it would work.
SmartThings refugee, so happy to be on Indigo. 10.12.6 on an i5 MBP w/Harmony Hub, Hue, DomoPad, Dynamic URL, Device Extensions, HomeKit Bridge, MatplotLib, Plex, uniFAP, Wunderground, Nanoleaf, LED Simple Effects, Airfoil Pro, Grafana.
Fri Jul 28, 2017 9:03 am
pocster offline
OOOOOOOOOOOOOOOOOO!; that would be magic if it works! - will try it!!!
Fri Jul 28, 2017 9:10 am
mat offline
just tried and didnt work, but someone else should also check :(
mini 10.11.6
Fri Jul 28, 2017 9:40 am
pocster offline
Bummer!. I will try later - I'm guessing it won't work though otherwise why would everyone do the file copying fudge?! :roll:
Fri Jul 28, 2017 10:40 am
