jay (support) wrote:We can't allow high-bandwidth data (live video or frequent image updates) or we wouldn't be able to afford to provide the service without significantly increasing the cost.
Different Computers wrote:Bkmar offered a suggestion on how to do this with his Security Camera plugin--the short version is that the cameras are off until you order a snapshot from the control page, which the control page then displays.
bkmar1192 wrote:Here is a convoluted idea that doesn't 100% solves the problem but would help.
Save two versions of the file one at high resolution and one at extremely low resolution.
Create a symbolic link that points to the low resolution image. Refresh the symbolic link file every second.
Create an action that, when clicked, changes the symbolic link to point to the high resolution image, waits a few seconds, and the switches back to the lower resolution.
Result: low resolution, and therefore less data, is uploaded every second. When you actually want to see the higher res version you click on the image and it uploads the higher res version and then switches back.
bkmar1192 wrote:
Btw: You can set each camera to different image quality so you could have a high res version and a low res version of the same camera. You'd increase the processing on your computer but it would allow you to use the carousel - one that rotated through the low res and one that looped through the high res.
How many cameras do you have?
