need help design the custom image names
Tue Jan 17, 2017 9:52 pm
there is a device/state that can be
-1/0/1/2/3/4/5/6/7/8/9
I have a drawing of my house and would like to have a green dot in
room 0 when state=0,
room 1 when state=1,
room 2 when state=2,
room 3 when state=3,
room 4 when state=4,
room 9 when state=9,
and blank otherwise in each room
The only way I have found to do this is to have 11 images per room (=10*11 = 110 images) There should be an easier way
currently i have blank images for room 5
and ONE green dot
is there an easier way to do this?
if I leave blank images out the algorithm tries to find a closets image and that might be a green dot.
Tue Jan 17, 2017 10:36 pm
ckeyes888 offline
Re: need help design the custom image names
Not sure if I really get what you're after but I reference the same set of images from any number
of variables, device states etc.
If it's just a green dot, or not, for all the rooms I would think one set of images would cover it.
Carl
Tue Jan 17, 2017 11:21 pm
i tried that, but if the state is not available as image Indigo will try to find an image name that is close - and that might be the green dot.
I created the 110 images and it works... but I am not happy with it ..
there are actually 10x10 combinations (you have to add the default name xx+.png too which makes it 11x10 images)
--- see the post http://forums.indigodomo.com/viewtopic.php?f=187&t=17846
Wed Jan 18, 2017 4:26 am
Why not have 10 variables (one for each room), two images per room (on and off), and then use a script to manage the variable values?
EDIT - you'd only need two images. 10 variables and 2 images
Wed Jan 18, 2017 8:07 am
I don't think you need a script, just use a two triggers (Device State Changed) for each room to set the room's variable e.g.. Becomes Equal To to value and becomes Not Equal To value.
The idea to use a variable is good :)
Wed Jan 18, 2017 8:27 am
So for 10 beacons I would need 10times 10 variables ...
I guess you have to bite the bullet one way or the other
Already created the png files. And it is working.
Also looked at the indigoulitily.py file that is mentioned in the docu. But that would mean to change indigo and keep it up to date every time it gets updated.
Anyway thanks for the suggestions.
Wed Jan 18, 2017 8:38 am
No you need one variable per room.
Lets take Room '0' as an example:
Set trigger 1 for Room '0' to if device State Changed becomes equal to '0', set room '0' variable to true
Set trigger 2 for Room '0' to if device State Changed becomes not equal to '0', set room '0' variable to false
Set your green dot images to be based on True/False
Repeat for room '1' e.g.:
Set trigger 1 for Room '1' to if device State Changed becomes equal to '1', set room '1' variable to true
Set trigger 2 for Room '1' to if device State Changed becomes not equal to '1', set room '1' variable to false
Should work, I think. :)
Wed Jan 18, 2017 9:06 am
Maybe I'm oversimplifying, but why not just do this:
10 variables, 1 per room
trigger on device state changes to run script
script reads dev state and sets corresponding room variable to on, all others set to off
Something like this:
rooms = {'variable ID room 1': 1, 'variable ID room 2': 2, 'variable ID room 3': 3}  # dict of rooms/state values
state = 2  # read the device state and set to int
for k,v in rooms.items():
    if v == state:
        indigo.variables.updateValue(k, 'on')
        indigo.variables.updateValue(k, 'off')
Wed Jan 18, 2017 9:26 am
Then multiply with number of beacons..
I can add the variable management to the plugin:
beaconXroomY = 0/1
that would then create X times Y times 2 variables?
in my case 35 times 10 = 350 variables
Using images path it is 11 images per 10 room it is 110 images for one beacon or 1000 beacons
I guess the crossing point is 6 beacons (10x11) =110 with variables and 110 with image method
it would be much easier if indigo would have a switch: don't do fancy interpolation(*): if value found use ON if not OFF image. That would require
r0+.png = empty
r0+on.pgn= image
= 20 images
this is the indigo code that should NOT be executed:
         if isIntCompat(value):
            intValue = int(value)
            if intValue == 0:            # case a)
               return fullPath
            stepPath = fullPathNoExt + u"+" + str(GetNextIntegerStep(intValue, 5)) + fileExt
            if os.path.exists(stepPath):   # case b)
               return stepPath
            stepPath = fullPathNoExt + u"+" + str(GetNextIntegerStep(intValue, 10)) + fileExt
            if os.path.exists(stepPath):   # case c)
               return stepPath
            stepPath = fullPathNoExt + u"+" + str(GetNextIntegerStep(intValue, 20)) + fileExt
            if os.path.exists(stepPath):   # case d)
               return stepPath
            stepPath = fullPathNoExt + u"+" + str(GetNextIntegerStep(intValue, 25)) + fileExt
            if os.path.exists(stepPath):   # case e)
               return stepPath
it will find something for rooms 0...4 by adding 5 to the value and try again.. ... not for rooms 5...9
Wed Jan 18, 2017 9:47 am
I'm afraid I don't know from beacons. Sorry.
I was reacting to:
So I saw 1 device and 10 rooms.
Wed Jan 18, 2017 9:56 am
DaveL17 wrote:
... So I saw 1 device and 10 rooms.
ditto :D
Wed Jan 18, 2017 11:18 am
if I create a state that is not an integer it should work!
room= "room:4" or something else
then the indigo fancy search does not kick in and it can only use either the exact file name of the default/fallback!!!
==> 2 images per room for all beacons
r4+.png = empty if something else
r4+room:4.png = green dot if =="room:4"
Wed Jan 18, 2017 11:33 am
johnpolasek offline
Technically, shouldn't it be "rPi X" rather than "Room X" until and unless you can get the distancing not only working reliably but somehow tied to an actual floor plan? Personally I have my doubts that signal strength correlated with distance will ever be reliable given the issues of walls and signal reflective surfaces and open and closed doors, etc, but strongest signal == closest Pi ought to be a pretty good indicator,,,
Wed Jan 18, 2017 11:44 am
yes that works but not with a ":" in the name OS X does not like : in file names
so the solution that seems to work
create a device/state or variable:
clostestRPItext has values = closesetRPI= -1/0/12/3/4/5/6/7/8/9 (eg " closesetRPI=5"
create image files
r0+.png = empty
r0+closestRPI=0.png == green dot
= 20 images
then for each beacon create one item in control page per room with "As image" = rX+.png where x = 0.../9 for each room.
... there is always a solution ...
Wed Jan 18, 2017 12:05 pm
and even better:
use 2 items to display
1. a semi transparent rectangle
2. text for the beacon
overlay both with the image on top.
then
r0+.png contains the rectangle
r0+closestRPI=0.png is the empty image
then it looks like:
Screen Shot 2017-01-18 at 12.02.07.png (8.63 KiB) Viewed 3764 times
when the beacon is present you can see the text here volvo key 1 /2 and when it is not present you see the rectangle and the text is a little bit visible. you could make the image non transparent with same color as background then
beacon present == text
beacon not present == background
