Use indigo variable to substitute URL on control page image
Sun Nov 15, 2015 8:36 pm
Quantum Flux offline
I have a control page for an iPad which has a refreshing image from URL.
Is it possible to use an indigo variable to substitute this URL?
Can't seem to make it work.
If not, does anyone have a good workaround?
Mon Nov 16, 2015 12:25 pm
Re: Use indigo variable to substitute URL on control page im
Unfortunately, substitutions are not available in the control page editor at the moment.
Mon Nov 16, 2015 1:19 pm
RogueProeliator offline
You need to go about it the other way -- keep the URL the same, generally pointing to a file:// URL located on your hard drive. Then instead of using a variable to change the URL, you change out the image file itself. The control page, upon the next refresh of the refreshing image, will pull the new file (from the same location).
From the control page standpoint, you are simulating loading a refreshing image from a website here, just that you can use a local file that you control and change out as necessary.
Adam
Tue Nov 17, 2015 4:51 am
Adam
Thanks. That sounds like a good solution. I'll set that up next weekend.
Thu Jul 23, 2020 11:30 pm
ppespepe offline
Hello Everyone!
I can see this thread is pretty old, Is there any update on this?
Thanks in advance!
PP
