[ANSWERED]control page element order and layering?
Fri May 16, 2014 6:35 am
Seeker offline
It seems that the ORDER in which an element is added to a control page determines how it is layered/ordered relative to other elements?
example: device_statetext1 is already on a page. I add image1 to the page. if I drag device_statetext1 ONTO image1, it goes behind image1. However, if I add a new copy of device_statetext1 to the page, it will go ON TOP OF image1.
Is this how this works? The newest items get ordered on top of previous items?
Fri May 16, 2014 7:27 am
Re: control page element order and layering?
Correct, the newest items go on top. You can use the Edit z-order checkbox to change the stacking order. You'll see 4 tiny arrows on the selection feedback for objects, as well as a number showing which z-layer the object is on. The left pair of arrows sends the selected object up/down a single layer at a time. The right pair sends the element all the way to the bottom/top of the layers.
Fri May 16, 2014 7:28 am
Seeker offline
perfect, thank you.
