[SOLVED] Image selection heuristics not updating for some
Sun Jun 28, 2020 4:18 pm
mgolden50 offline
Re: [SOLVED] Image selection heuristics not updating for som
Also please note that the statements following the If statements are intended properly. It's just that the code function for the forum is still not working properly for me.
Sun Jun 28, 2020 4:26 pm
It looks like you are assigning the variable value to be the entire file name. It should just be the selector part between the + and the .png.
For example, instead of setting the variable value to weather+sunny.png set it just to sunny. Inside the Control Page editor you select the base variable name (weather+.png) so it knows what image group to select from (everything that starts with weather+), so the variable value should just be the selector part after the + (and before the .png).
Sun Jun 28, 2020 5:25 pm
mgolden50 offline
That did it!
Thanks again
