Time stamps and variables
Tue Mar 02, 2021 5:12 pm
jmiked offline
I'm looking for away to compare the current time to a time stamp stored as a variable. The intent is to perform an action if the difference between the two is, say, greater than 8 hours. I've not found a way to do this yet. Any ideas?
Thanks.
Mike D.
Wed Mar 03, 2021 5:58 am
Re: Time stamps and variables
How frequently do you want to check the difference? How often does the timestamp variable change and what changes it?
Personally--depending on the nature of the data--I would use a schedule that runs every X units of time (like every five minutes) that runs a Trigger with the following Python script as a condition:
import datetime as dt
now      = indigo.server.getTime()
var      = indigo.variables[389753528].value
time_var = dt.datetime.strptime(var, "%Y-%m-%d %H:%M:%S.%f")
diff     = now - time_var
if diff > dt.timedelta(hours=8):
    return True
and then fire a trigger when the result is true to do whatever you need to do. The script is untested but should be pretty close.
Fri Mar 05, 2021 8:58 pm
jmiked0 offline
The time variable (ActivityLast) could be updated anywhere between a few minutes and 8 hours or so. I'd like to check it every 30 minutes or so.
Essentially, the variable gets set by a motion detector being triggered. If it does not get triggered for 8 hours (or whatever I decide) and the AtHome flag is set, it invokes an action to send a message to my in-town relatives to check up on me after giving me a chance to respond to an alert. I'm well past retirement and live alone, and this is in addition to my Apple watch which is good for emergencies like falls, but not so much if I am unresponsive.
I do have a system set up now that monitors a variable set by the motion detector, but it only checks at specific times of the day. I'd like to have something with a bit intelligence.
Mike D.
Sat Mar 06, 2021 6:57 am
Sounds like the above script should to the trick then.
Schedule: run every 30 minutes.
Condition: the Python script above.
Action: Notify your in-town relatives.
The script above presumes a standard format for the timestamp variable, so if your's is different we'd have to tweak the script a bit. Of course, you'd also have to change the variable id to the one that matches your timestamp variable.
Tue Mar 09, 2021 11:09 am
McJohn offline
Nice script Dave, thanks!
Question; we have changed the script into the European date format and without the milliseconds, that works.
But we display also this date and time into a control page.
When we delete the year denotation, the script won't work anymore (no red errors but nothing happens).
With this Indigo Variable input: 2021-09-03 16:54 the script works perfect.
With this Variable 09-03 16:54 and this script content %d-%m %H:%M nothing happens anymore.
What have we done wrong?
And is it also possible to use only the time? (without a date).
Thanks for your support!
John
Tue Mar 09, 2021 11:16 am
Hello John - sorry to hear that you're having trouble adjusting the code. Please check your script for things like errant spaces and proper indentation (if needed) as this code works for me:
#! /usr/bin/env python
# -*- coding: utf-8 -*-
var = "09-03 16:54"
now = dt.datetime.now()
var_dt = dt.datetime.strptime(var, "%d-%m %H:%M")
print(now - var_dt)
Result: 44194 days, 18:21:36.113743
Tue Mar 09, 2021 11:46 am
McJohn offline
Hi Dave
Thank you so much for the fast reply.
I think your new script is another script than the first one?
We want to use this script:
if diff > dt.timedelta(hours=1):
    return True
But then with this Indigo Variable input: 09-03 16:54 (thus without the year, seconds and milliseconds)
And another one for only the time: 16:54
Is that possible?
Tue Mar 09, 2021 2:35 pm
Yes, it was different. I was just meant to test your inputs. These *should* work. Obviously, you'll need to change the variable ID to match your variable(s).
09-03 16:54
time_var = dt.datetime.strptime(var, "%m-%d %H:%M")
    return True
16:54
time_var = dt.datetime.strptime(var, "%H:%M")
    return True
Wed Mar 10, 2021 3:51 am
McJohn offline
Thanks for your time and input Dave.
There is something strange going on.
We tried your first script from your last post (with only the date and time) also earlier and now again and as said in our post before, there is no result (no error, nothing happens).
When we set the timedelta hours for example to 2000, there is no message; "Script did not return a valid Boolean".
When we edit the script and include the year denotation (include %Y) it works perfect.
When we delete only the %Y in the code (and of course the Variable input is also without the year), the script won't work anymore.
This problem is also for the time script ("%H:%M")
Or the Python script could only calculate with the year denotation?
or maybe the European date and time settings of the Mac (Wednesday, 10 March 2021), gives the problem?
John
Wed Mar 10, 2021 6:14 am
Turns out, in my haste, I gave you incomplete (also known as bad) advice. For lack of a better way to describe it, Python is imputing the missing bits of time and using its best guess which, as it turns out, is a really bad guess. Consider this (the script takes Indigo out of the equation):
var = "09-03 16:54"
print(time_var)
print(diff)
1900-09-03 16:54:00
44017 days, 13:01:32.759175 (close to the result above which I failed to highlight).
Not very helpful.
Without knowing the complete value to work from, both datetime and very useful dateutil libraries struggle. You could "manually" adjust the input value with Python by adjusting the variable string before working with it, but that is fraught with peril. For example, if you assert the current year, this will break comparisons that span years.
I would suggest that the easiest and most robust way to solve the problem is to see if you can change the "shortened" variable values to full timestamps. If that's not possible, we can work on creating some custom scripts that will work for your circumstance.
Wed Mar 10, 2021 8:12 am
McJohn offline
Thanks for the explanation, I'm glad we're not crazy :roll:
No problem, we are going to use the full timestamp within an extra Indigo Variable. (They are inexhaustible :D )
(The strange thing is without the seconds and milliseconds it's working well)
Thanks for all your support.
Case closed.
John
Wed Mar 10, 2021 9:38 am
Glad to be some, if not completely marginal, service. :D
