Timing of variable change
Tue Nov 04, 2014 8:15 am
ken_jacobs offline
I have a string of actions in which I initially set the value of a variable to the value of another variable. The actions following the variable change use the modified variable value. I find that the actions use the old value then the variable value is changed. I ended up writing an applescript to make the change and that solved the problem.
Tue Nov 04, 2014 8:20 am
Re: Timing of variable change
I think I know what might be occurring but can you copy/paste your script into a reply so we can see more details?
Tue Nov 04, 2014 8:22 am
I think (possibly) the reason that the actions following the variable change use the old values is because when you launch a series of actions, Indigo runs them in parallel. So it is likely that the variable is getting changed after the action that uses it.
I believe it is on the request list for Indigo to be able to run actions one after the other.
In the meanwhile, the simplest solution is to put a small delay in the subsequent actions (i.e. the actions that need the new variable value) of say 0.5 seconds. :)
Tue Nov 04, 2014 8:30 am
Ah, yes. If this is not a script but a list of actions in the GUI then autolog is correct and the delay is the workaround.
