Sending commands to Raspberry PI on the same LAN via Indigo
Tue Feb 12, 2019 1:21 pm
mollynittany offline
Using latest Indigo version. Want to send various commands to a Raspberry Pi v3, via actions / action groups. RPi is on the same LAN as the Indigo server (v 7.x)
Any suggestions? Sorry if a stupid / noob question.
Tue Feb 12, 2019 1:51 pm
Are u using pibeacon?
It comes build in with that function
Otherwise you will need to program yourself
Tue Feb 12, 2019 2:00 pm
Re: Sending commands to Raspberry PI on the same LAN via In
No, I want to login into the PI and send commands via the CLI to tell it to send commands to a bluetooth receiver, not a beacon, that is nearby.
Tue Feb 12, 2019 2:01 pm
Yes pibeacon can do that
Can send any command to an rpi
Tue Feb 12, 2019 2:08 pm
Thanks, I'll give it a try.
Tue Feb 12, 2019 2:10 pm
kw123 wrote:
Otherwise you will tomptogrM yourself
:?: :?: :lol:
Tue Feb 12, 2019 2:13 pm
I hate auto spell checker
Sun May 24, 2020 7:35 pm
rustyhodge offline
I'm late to the game here, but you could use SSH, with a ssh key created without a passphrase, then you can just ssh pi@x.x.x.x command option etc
to generate a key on the Mac, go into terminal and:
sshkeygen -t rsa -b 2048
hit return to accept all the defaults.
Then copy the contents of the id_rsa.pub file to the pi's .ssh/ directory in a file called authorized_keys and you can connect without a password.
You'll possibly need to create the .ssh directory in your home on the Rpi.
If it doesn't work then the permissions on the file or the .ssh directory are wrong.
Sometimes I shortcut by creating a ssh key on the Pi as well, which will create a directory with the proper permissions.
Mon Jul 20, 2020 3:42 pm
mundmc offline
This was exactly what worked for me. Hardest part was learning about keys.
