I have a trigger executing that is not in the list.
Sun Sep 04, 2022 5:48 pm
hwitten offline
I converted all triggers/actions using BetterEmail to Email+.
All good except that I still have one executing randomly and I can't find it.
Of course it errors.
Have gone through everything that sends email but can't find the offender.
Not a biggy as it's just an error line in the log but I'm concerned about future troubles that may be lurking.
I'm thinking possible database corruption?
Any thoughts recommendations?
Sun Sep 04, 2022 6:33 pm
Re: I have a trigger executing that is not in the list.
Hard to diagnose without the error line and a few lines before and after...
Sun Sep 04, 2022 7:19 pm
hwitten offline
BetterEmail plugin has been removed.
                Set Time
   Email+                          sending email 'Who Disarmed' to 'xxxx;xxxx' using BetterEmail SMTP
   Email+ Error                    BetterEmail SMTP: SMTP server connection error: [SSL: DH_KEY_TOO_SMALL] dh key too small (_ssl.c:997)
Sep 4, 2022 at 6:03:00 PM
   Schedule                        Set TimeStamp
   Schedule                        Set Date
   Schedule                        Set Time
Sep 4, 2022 at 6:03:33 PM
   Z-Wave                          received "022 - Luminance" sensor update to 195 lux
   Z-Wave                          received "022 - Humidity" sensor update to 48%
   Z-Wave                          received "022 - Dining Tamper Switch" sensor update to 74.1 °F
Sep 4, 2022 at 6:04:00 PM
   Schedule                        Set Date
   Schedule                        Set Time
Sep 4, 2022 at 6:05:00 PM
Sun Sep 04, 2022 7:24 pm
hwitten offline
Running 2022.1.1 on an M1, Big Sur. Plugins up to date.
Sun Sep 04, 2022 8:46 pm
What server is this connecting to?
Do you have any non-standard SSL libraries installed?
Sun Sep 04, 2022 8:51 pm
hwitten offline
Not that I know of. The M1 is dedicated to Indigo. Runs Reolink app to display local network cams.
I had same error on some triggers that were visible while I was migrating to Email+ and it always worked to fix it.
The problem this time is that I can not find the trigger entry to make the change.
Sun Sep 04, 2022 8:53 pm
Please answer my question. What server is the "BetterEmail SMTP" device configured for?
The trigger is not the issue. That server device is the problem. If you're not using that device, delete it.
Sun Sep 04, 2022 9:01 pm
hwitten offline
Sorry missed it.
I don't think it's actually connecting to an smtp server.
The error would be valid with BetterEmail plugin installed but I removed that unless there is some remnant hiding somewhere.
This has been going on for a while and M1 has been rebooted several times, hence being at a loss.
Sun Sep 04, 2022 11:17 pm
hwitten offline
Had expected removing the Plugin would remove everything related but as you expected it did not.
Have now deleted the BetterEmail SMPT device so hopefully good going forward.
Big Thank You.
