Trigger takes no action anymore AND cannot be modified
Sat Feb 01, 2020 10:47 am
Hans Kiesewetter offline
Hello reader,
I have a trigger that worked fine in the past, (months ago).
    Trigger: Variable changed (variable 1 specified)
    Condition: Always
    Action: Variable actions / insert time stamp into variable. (variable 2 specified)
Last two times this trigger should have come into action it failed. So tried to find out why.
All seems OK, but when I pressed the button "edit action settings" nothing happened.
I could change the trigger, part, the condition part. I even could change the action part into an other action, but when reversed to "insert time stamp into variable" I cannot specify the needed variable for this time stamp.
There is the button "Edit action settings" pressing this button gives the regular visual impression that you press it, but is does not result into the expected pop-up of a new window to specify the required variable.
screenshot
Schermafbeelding 2020-02-01 om 17.41.22.png (87.72 KiB) Viewed 920 times
Sat Feb 01, 2020 1:12 pm
Re: Trigger takes no action anymore AND cannot be modified
Try stopping and restarting the Indigo Server. It sounds like one of Indigo's sub-processes that handles that particular action might have died. If that doesn't work then open the Event Log window after you press the button and copy/paste its contents into a reply post for me.
Sat Feb 01, 2020 2:50 pm
Restarting Server solved all problems.
Thanks Matt
:D
