I set up a trigger than when a door is opened, it brightens the lights in one room by 30 and then 2 seconds later dims them by 30.
I get the strangest behavior:
Sometimes when I start with the lights off, it brightens them to 30 and then according to the indigo log " Sent INSTEON 'Den Lights' on to 0"
This seems to confuse things (or me), since the icon in indigo does in fact show the light as on, and shows the brightness as 0. The behavior on my lights is 1 of the 6 LED bulbs on that switch is dimly on. I would think that a brightness of 0 is "off".
Other times it brightens to 30, and then 2 seconds later dims to 1.
Clearly this is not the (my) expected behavior. I'm pretty sure I could write a python script to handle this better, but it seems the triggers should be capable of doing with their action set.
