I'm in the process of installing a water tank level Sensors inside my under ground water tank, where the sensor output voltage changes proportional to the water level. This sensor is connected to a Fibaro Smart Implant that measures the voltage change.
I want to create a series of virtual devices that are controlled by a trigger event (change in voltage) that will turns on signal lights on control page. i.e I may have ten signal lights that represents different set water levels (10%).
Do you know if this is possible and if so, how do I achieve this?
