Modifying my Garage Door alerts
Thu Jul 11, 2019 5:54 am
midd offline
I've been using the garage door alert ( found here https://wiki.indigodomo.com/doku.php?id=iolinc_garage_door_alert) for years. It's been awhile so I still have the Applescript version instead of the Python script that was recently added.
Since moving to a VPN, I can no longer send emails out without disconnecting from the VPN. My workaround in this case to use Pushover to send my notifications.
Can the script be modified to use Pushover?
dev = indigo.devices[IOLINCID] # "IO Linc"
if not dev.states["binaryInput1"]:
    indigo.server.sendEmailTo("ADDRESSHERE", subject="The garage door is OPEN!!")
Or do I use the conditions tab of the trigger to check what the status of the binary input of the I/OLinc is?
Indigo 7, Mojave on a 2009 Mac Pro..
Thu Jul 11, 2019 6:27 am
Re: Modifying my Garage Door alerts
This should work:
    pushPlugin = indigo.server.getPlugin("io.thechad.indigoplugin.pushover")
    props = {
        'msgTitle': "Indigo Alert",
        'msgBody': "The garage door is OPEN!!",
    if pushPlugin.isEnabled():
        pushPlugin.executeAction("send", props=props)
Thu Jul 11, 2019 6:28 am
That would probably be easier. Use conditions to check the state, then you could send the notification without any scripting.
Thu Jul 11, 2019 8:33 am
+1
Thu Jul 11, 2019 9:12 am
midd offline
Thanks. I’ll try this out when I get home.
FlyingDiver wrote:
This should work:
    props = {
