Capture ID of running Trigger
Sun Dec 31, 2017 5:07 am
jeremyjjr offline
I need a python trigger script to identify the ID of the parent or invoking trigger.
thisTrigger = indigo.triggers.???
Any ideas?
Jeremy.
Sun Dec 31, 2017 5:57 pm
Re: Capture ID of running Trigger
Doesn't exist - currently actions executing aren't really connected to the event that caused them (at least within the server at runtime).
One way to fake it is to make your script a shared python function, then from your trigger rather than directly executing the script you call the function and pass in the ID of the trigger. So each trigger that you want to execute the function from would execute the following script (I'm assuming the name from the example above):
import indigo_attachments
indigo_attachments.myTriggerFunction(IDOFTRIGGERHERE) # Insert the ID of the trigger calling this script
So, each trigger will have it's own script, but it'll just be the 2 lines above. All the real work is done in your shared function.
Users browsing this forum: Google [Bot] and 1 guest
