Long vs Short Switch Press Trigger;
Posted:
Sat Feb 04, 2017 9:39 pm
by Craig_H
Hello,
Does anyone know how to implement a long push / slow push trigger with a ToggleLinc?
I'd like to be able to turn ON or OFF a light with a ToggleLinc by pushing it ON or OFF in a short push.
If I push it ON and hold it, I'd like it to increase brightness in increments , likewise if I push and hold OFF, decrement brightness.
I tried a couple searches, but don't really know what to search for.
Craig
Re: Long vs Short Switch Press Trigger;
Posted:
Mon Feb 06, 2017 10:13 am
by jay (support)
The 3rd party
Dimmer Extender plugin may do part of what you're looking for - it provides trigger events for start/stop brightening/dimming. The only trouble might be (you'd have to try) if the UI in the plugin only shows dimmer type devices. The ToggleLinc is an on/off device (it doesn't dim) in how it controls the load attached so Indigo treats it as such. However, it does send out the start/stop brighten/dim commands if you hold it up or down (even though it's load will never dim/brighten).
Posted:
Sat Oct 28, 2017 4:55 pm
by Colly
I'm looking at doing something similar only it is with a Fibaro universal sensor. Can I trigger different actions based on a long/short or even double press within a short period? If so how is this best achieved?
Posted:
Sun Oct 29, 2017 2:03 am
by howartp
If you go to Triggers > New > ZWave command received* > (Select your universal Sensor), do you get Click/Double Click/Hold/Release?
(*Cant remember the exact wording or if it’s under a submenu such as Device actions)
If you don’t have those options, try my Scene Controller Plugin and see if you get any response in debug mode.
Posted:
Sun Oct 29, 2017 2:08 am
by howartp
Ah, just read manual.
Parameter 14 is your friend.
It does send Scene commands and thus will definitely work with my Scene Controller Plugin if it doesn’t natively.
Posted:
Sun Oct 29, 2017 3:11 am
by Colly
Thanks howartp.
As a now retired colleague of mine once said RTFM! (read the f***ing manual)
Posted:
Sun Oct 29, 2017 3:26 am
by howartp
Yep, reading the FLIPPING manual is always useful. :p
