Mitchemi wrote:Basic question. I have installed a hidden door sensor and paired it to a switch. It is working but turns the light on when the door is open and then turns it off when it is closed. I want the light to stay on for a period of time say five minutes after the door is opened. I can't figure out how to do this. Can someone help me please.
When you say "paired", how did you do it? If you did it by using a pair of Triggers (one for when the door opens, the other when it closes), they've got you covered... If you want the light to stay on for some amount of time after the door opens no matter what happens after that, you don't need the Close trigger at all; once you choose the Device Action of Light on in the "State becomes Open " trigger, there is an option there to Auto Off after whatever interval you want to set. If you want it to stay on for some period after the door closes, look at the bottom of the "Actions" tab on the "State becomes Closed" trigger; there is an option there that you can use labeled "Delay" on the close trigger to wait however long you want before sending the light off.
