Hi guys,
well I've successfully installed my Fibaro leak sensor in the laundry room.
So far, an alarm is triggered when the contacts (extended the contacts with a 2 meter cable) are in water.
As well via email, Prowl and the acoustic signal.
Well, one issue: I have no idea how-to switch off the acoustic signal via Indigo.
For sure, I could try to get the contacts dry, but so fast?
And here I do need some help:
Here is my plan:
1. Device goes on when water is detected. Mail, Prowl and an trigger 10 minutes are started (see attachment, so far realized).
2. So, Trigger runs also for 10 minutes. Now I want to cancel the acoustic signal. How?
3. For the next 20 minutes I want to send mail in 5 minutes intervals (as an reminder).
4. The leak sensor should return to Off, so to be ready for anther alarm.
I need your help for 2. to 4. important is 2. (turn off the beeps on the device).
I can't find anything how to set the water sensor to OFF.
Best,
yassi
