Insteon open/close sensor 2843-522 help with triggers
Tue Sep 08, 2015 2:27 am
Pdoc offline
Hi all,
Very new to inteon and indigo I searched but couldn’t find info on setting up a wireless open/close sensor so it turns on a light when opened and the light stays on when closed then off when opened and closed again. Basically a toilet door opening and closing but leaving the light on when in there
any help/direction would be much appreciated
Cheers,
Pete
Tue Sep 08, 2015 2:49 am
Re: Insteon open/close sensor 2843-522 help with triggers
I am using z-wave devices but it should be similar :)
I have two triggers set-up as follows:
The first to use when entering (when the light will be off):
The second when leaving (the lights will be on):
The triggers only work when it is dark (after sunset).
Note the 5 second delay on leaving - gives you time to see when going out of the doorway ;-)
Hope this helps :)
Tue Sep 08, 2015 6:28 am
Pdoc offline
Thanks Heaps autolog
that worked a treat much appreciated
cheers
Cheers,
Pete
