[ANSWERED]: newbie question - battery notify, heating sync..
Posted: Mon Sep 15, 2014 5:15 am
Switching from fibaro HC2 to Indigo6.
So far, indigo is extremely more reliable and functional. Really impressed.
Quite a few basic questions
1) Easiest way to provide "low battery" notifications?
I.e. some trigger event for all battery-powered devices.
I'm not seeing how to do that right now, obviously I'm missing something It's basic functionality which should be exists.
Now it is possible to configure only per-device (triggers).
May be the good idea to add some virtual device model like "All battery-powered"?
2) How to sync thermostats? I.e. I've got (each room) wall thermostats HRT4-ZW and Danfoss Valves.
On HC2, I synced them with lua code (temperature changed manually on the wall thermostat will be pushed to Danfoss valve).
With Indigo, I thought it will be really easy to do that with triggers / variables, but there is no way to "setpoint" thermostat from a variable in the current version of the software.
Is it possible to add this feature? Will be useful.
Right now, the only way is Python / AppleScript?
3) Is it possible to ask to add "and / or" device logic to triggers? I.e. "if this motion sensor or this motion sensor triggers".. Right now, all triggers are "per a single device", which is forcing us to duplicate triggers (not so convenient in case of some changes to make)
I understand that it is possible (quite easily) to do that with variables, but still it is more complicated...
