Because things are never as straight forward as you first think I am trying to use a minimote to control a Fibaro rgbw controller. The original plan was easy..create a trigger using a button press from the minimote to toggle the on/off state of the relevant channel of the rgbw controller, however, as I found out sometime ago the rgbw channels do not respond to on/off commands reliably, only responding to changes in level ( brightness). So I'm looking for a way to toggle between a brightness level of 0 and 100% so that I can use just one button to toggle the lights connected to the RGBW controller channel on and off.
Hope this makes sense
Colin
