Timers not working?
Wed Feb 18, 2015 9:41 am
cutmoney offline
Timers not working?
I have a few triggers that activate after a timed delay (bathroom fans turning off after light switch off received). These have worked in the past but no longer seem to function, I don't see anywhere where the timers are triggering. I have another trigger that immediately shuts off the fan with a double tap, which works fine, the timers just do not seem to be working any longer. Is this a bug or am I missing something? Using Indigo Pro 6.0.20.
Wed Feb 18, 2015 10:09 pm
Re: Timers not working?
No bug that we know of. Can you include Event Log lines from a bit before the trigger fires until after the delay was supposed to fire? Also, attach an image of your trigger config and the action config. I assume you're talking about delayed actions, right?
Sat Feb 21, 2015 5:25 pm
hamw offline
I am having a similar problem, as noted here. viewtopic.php?f=104&t=13128
Let me know if you figure it out.
