Trigger Action at specific time
Thu Dec 03, 2020 2:47 am
McJohn offline
Is there a standard direct way to make a Trigger action at a specific clock time?
(not a delayed action)
Or only by detour to create a separate extra Schedule which must be turned on and off separately?
Thu Dec 03, 2020 6:28 am
Re: Trigger Action at specific time
I think creating a schedule to fire the action is your best bet. Of course, you can create a new action tied directly to the schedule, but I presume you mean to fire an action that you've already created.
Thu Dec 03, 2020 9:21 am
McJohn offline
Thanks for the suggestion Dave.
The challenge is that a Scheduled action always will be fired .
So, the only way is to switch this Schedule on (and later off again) when the Trigger fires.
Future request: Trigger action at specific time
a more direct and simple way I guess :D
Thu Dec 03, 2020 11:03 am
Based on your comment, it sounds like there isn't a conditional that will work in this instance? Something to the effect of, "only when variable X is True" or something like that?
Thu Dec 03, 2020 11:25 am
This is exactly what a Schedule is, so I guess I'm not fully understanding exactly what you're trying to do. Please fully describe the scenario so we can understand your request.
Fri Dec 04, 2020 4:46 am
McJohn offline
That's right Dave, you are a smart man :wink:
The case is: Alarm system gives a (one way) X10 signal when a window has been opened.
(gives not an X10 signal when window is closed again).
When for example this window is opened by somebody else at 6.00 am, we want a message at 7.45 hour (breakfast trough airfoil speakers) that the window was opened (otherwise alarm system can not be armed).
So, we thought when a Trigger catches this X10 signal (that works) , the simple action of this trigger will be scheduled at 7.45 am.
Fri Dec 04, 2020 5:43 am
So that sounds pretty simple. X10 signal sets a variable. Scheduled actions run only if variable is set, says message, clears variable.
Fri Dec 04, 2020 8:30 am
+1
Sat Dec 05, 2020 1:23 am
McJohn offline
Fortunately there is indeed always a solution with Indigo; one way or the other. :D
But the original question was:
Not.
No problem!
Sat Dec 05, 2020 11:22 am
Your question wasn't specific enough, so the answer to the question is "yes", that's exactly what a schedule is for...
Your question, phrased correctly: "Can a trigger directly schedule an action to run at a later specific time". The answer is no, though a trivial solution exists.
Specificity is always the best way to ask questions and receive firm answers.
Mon Dec 07, 2020 3:11 am
McJohn offline
With all those years of experience I thought that you would understood my question described in detail.
(formulated with the already standard Indigo schedule solution)
Next time your customer.. will explain it more clearly special for you. :D
