Error/Failure Trap routing
Wed Jan 16, 2019 4:50 pm
miketeel offline
Not sure this is possible but thought I'd ask. From time to time a device fails to acknowledge and I guess times out. In addition, sometimes due to power failure a schedule may be missed (server is off during the time it was scheduled to run.) Could/has a routine been written that would check the status of devices and compare them against the status they should be at based on schedules & triggers?
Wed Jan 16, 2019 6:05 pm
Re: Error/Failure Trap routing
While technically impossible, it would be so complex that it's just as well to say it's impossible.
You can trigger on failures though (with even more granularity with Indigo 7.2's new SQL Logger feature to trigger via a regex match on the event log line message).
