GD00Z-8 Garage Door Controller
Thu Apr 21, 2022 9:38 pm
JBB offline
Hi. Indigo 2021.1 release notes state: ""Added support for GoControl/LinearLinc Garage Door Controller (GD00Z-8)."
I have successfully paired this device (with encryption, as it requires).
Indigo can open/close the door via the controller. However, the status (open/close state) does not update based on the associated sensor that comes with the GD00Z-8. The status will only update with a manual status refresh.
Has anyone successfully used this device, or can otherwise offer guidance?
Thank you.
Fri Aug 12, 2022 3:51 pm
nlagaros offline
Re: GD00Z-8 Garage Door Controller
I have observed this exact behavior. The status does not update after an open or close unless initiated manually.
Fri Aug 12, 2022 5:11 pm
nlagaros offline
I have an action that runs every minute to update the status. It works, however the instruction and response is written to the Indigo log even though I have checked the box to suppress.
Fri Aug 19, 2022 10:35 am
nlagaros offline
Matt, Jay -- any thoughts. I've been scouring the Internet but cannot find any leads.
Fri Aug 19, 2022 11:01 am
Can you either turn on Zwave debug or put a Zwave Watcher (plugin) on it to see if/what it has to say about anything?
Fri Aug 19, 2022 2:14 pm
nlagaros offline
Thanks. I have both debugging and the plugin for the device turned on. Output is below. Note I do not see any broadcasts come in after the garage door is opened.
This is a command to open the garage:
Aug 19, 2022 at 4:09:35 PM
   Z-Wave Debug                    SENT nonceRequest: 01 09 00 13 0E 02 98 40 25 1C 08
   Z-Wave Debug                    RCVD nonceRequest: 01 18 00 13 1C 00 00 0D 00 C4 7F 7F 7F 7F 01 01 03 00 00 00 00 02 03 00 00 23 (node ACK)
   Z-Wave Debug                    RCVD nonceRequest: txTransmitTicks 13, txHopCount 0, txRSSIs 196 127 127 127 127, txACKChannelNum 1, txLastTxChannelNum 1, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 2, txRouteTries 3, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
   Z-Wave Watcher Debug            Raw command sent (Node 14): 01 09 00 13 0E 02 98 40 25 1C 08 (True)
   Z-Wave Debug                    RCVD nonceReport: node 014, nonce 93 8F D9 AA E1 63 96 63
   Z-Wave Debug                    RCVD nonceReport: node 014, nonce 49 BC 6E 36 EA A0 B2 33 (duplicate -- overriding previous)
   Z-Wave Debug                    RCVD nonceReport: node 014, nonce D0 82 C3 42 4A 8F FB 7F (duplicate -- overriding previous)
   Z-Wave Debug                    SENT setBarrierValue: 66 01 FF (encrypted)
   Z-Wave Debug                    RCVD setBarrierValue: 01 18 00 13 1D 00 00 03 00 B9 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 52 (node ACK)
   Z-Wave Debug                    RCVD setBarrierValue: txTransmitTicks 3, txHopCount 0, txRSSIs 185 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
   Z-Wave Watcher Debug            Raw command sent (Node 14): 01 1E 00 13 0E 17 98 C1 77 DE 9D 2F 5C 48 B1 6A AB FB 41 E6 D0 2E A7 A8 70 EF E4 0A BD 25 1D 94 (True)
   Z-Wave Debug                    RCVD nonceReport: node 014, nonce 2B 3F 5A 92 29 F7 6C CD (saved for next send)
   Z-Wave                          sent "Garage Door Controller (Bay 1)" open
This is a manual status reqeust:
Aug 19, 2022 at 4:10:12 PM
   Z-Wave Debug                    SENT nonceRequest: 01 09 00 13 0E 02 98 40 25 1E 0A
   Z-Wave Debug                    RCVD nonceRequest: 01 18 00 13 1E 00 00 02 00 B9 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 50 (node ACK)
   Z-Wave Debug                    RCVD nonceRequest: txTransmitTicks 2, txHopCount 0, txRSSIs 185 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
   Z-Wave Watcher Debug            Raw command sent (Node 14): 01 09 00 13 0E 02 98 40 25 1E 0A (True)
   Z-Wave Debug                    RCVD nonceReport: node 014, nonce 16 22 18 B4 9A 35 0B 46
   Z-Wave Debug                    SENT requestBarrierStatus: 66 02 (encrypted)
   Z-Wave Debug                    RCVD requestBarrierStatus: 01 18 00 13 1F 00 00 02 00 B9 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 51 (node ACK)
   Z-Wave Debug                    RCVD requestBarrierStatus: txTransmitTicks 2, txHopCount 0, txRSSIs 185 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
   Z-Wave Watcher Debug            Raw command sent (Node 14): 01 1D 00 13 0E 16 98 C1 C1 E1 ED 39 39 5D 33 CC 9B 78 9E 16 32 11 D2 C2 56 C3 2D D6 25 1F D3 (True)
   Z-Wave Debug                    RCVD unsolicited nonceFetch while waiting for nonce reply -- requeuing and bailing
   Z-Wave Debug                    . .  requestBarrierStatus: requeuing 1 unsolicited packets
   Z-Wave Debug                    waiting up to 3.0 seconds for module reply after sending request
   Z-Wave                          sent "Garage Door Controller (Bay 1)" status request
   Z-Wave Debug                    RCVD nonceFetch: node 014
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 0E 0A 98 80 E5 C3 2E CF E2 F0 11 4F 25 20 6F
   Z-Wave Debug                    RCVD nonceReport: 01 18 00 13 20 00 00 04 00 B9 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 68 (node ACK)
   Z-Wave Debug                    RCVD nonceReport: txTransmitTicks 4, txHopCount 0, txRSSIs 185 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
   Z-Wave Debug                    . .  nonceReport: requeuing 1 unsolicited packets
   Z-Wave Debug                    RCVD nonceReport: node 014, nonce 12 3A 68 25 D1 14 8A EE (saved for next send)
   Z-Wave Watcher Debug            Raw command sent (Node 14): 01 11 00 13 0E 0A 98 80 E5 C3 2E CF E2 F0 11 4F 25 20 6F (True)
   Z-Wave Debug                    RCVD encryptedPacket: 00 66 03 FF (decrypted)
   Z-Wave Debug                    RCVD requestBarrierStatus: 01 09 00 04 00 0E 03 66 03 FF FF
   Z-Wave Debug                    . .  requestBarrierStatus: node 014, endpoint None, value 255
   Z-Wave                          received "Garage Door Controller (Bay 1)" status update is open
   Z-Wave Watcher Debug            Raw command received (Node 14): 01 08 00 04 00 0E 02 98 40 9D
   Z-Wave Watcher Debug            Command class: 98v1
   Z-Wave Watcher Debug            Command not yet decoded: 98 40 v1
   Z-Wave Watcher Debug            Raw command received (Node 14): 01 09 00 04 00 0E 03 66 03 FF FF
   Z-Wave Watcher Debug            Command class: 66v1
   Z-Wave Watcher Debug            Command not yet decoded: 66 03 v1
   Z-Wave Watcher Debug            Raw command received (Node 14): 01 1D 00 04 00 0E 17 98 81 22 2C DB B8 BA 46 49 21 1D 14 DD 5D E5 00 A4 79 64 45 7E 1D 14 41
   Z-Wave Watcher Debug            Command not yet decoded: 98 81 v1
Fri Aug 19, 2022 2:49 pm
Hmmm
What is interesting is that the manual says it uses 'scene' command classes, but it's obviously responding to and sending 'barrier' commands.
I presume there's an association for Group 1 to Node 1 in the Interfaces > Zwave > Manage Associations?
Fri Aug 19, 2022 3:07 pm
nlagaros offline
howartp wrote:
Hmmm
I checked the associations and I see just that - controlling device 14, controlling group 1, responding device 1
Fri Aug 19, 2022 3:10 pm
Okey dokey.
Calling @Matt/@Jay... :)
Sat Aug 20, 2022 5:54 am
nlagaros offline
I think I figured the issue out. I have an original Aeotec zstick 5. It does not support S2 security, only S0 from what I am reading. The GD00Z-8 will not send unsolicited notifications unless S2 is enabled.
I am going to buy a new zstick. I guess the question is which one to get.
Sat Aug 20, 2022 10:22 am
I'll let Matt elaborate, but Indigo doesn't support S2, so replacing your stick won't help. Matt's using one of these I believe so perhaps he can shed some more light.
Sun Aug 21, 2022 1:22 pm
Unfortunately if it doesn't send unsolicited updates without S2 then Indigo isn't going to receive them. Adding S2 support is on our request list, but it is a massive feature so won't be happening in the short term. The one I have is much older (GD00Z-4) and doesn't have the S2 requirement, apparently.
