How to show "Device Name"
Fri Apr 15, 2022 11:27 am
jroach offline
I have some trigger, schedules where I would like to see what devices are being effected. I am trying to identify devices for troubleshooting and I have to go into one then cycle "Next/Prev" to see the detail. For me this seems to be for those devices that use a plugin (hue, denon, airfoil, etc). Maybe I'm missing something when I setup the device that would help.
Fri Apr 15, 2022 11:45 am
jroach offline
Re: How to show "Device Name"
I forgot the attachment.
Screen Shot 2022-04-15 at 10.15.59 AM.png (247.66 KiB) Viewed 2951 times
Fri Apr 15, 2022 3:08 pm
This would be an enhancement to the Hue Plugin since the plugin is responsible for that string. Note, however, that if you change the device name after you've last edited the action the old name will still appear - it is not dynamically generated (nor can it be currently).
Fri Apr 15, 2022 4:23 pm
jroach offline
Jay, thanks. That explains why it looks like that for all my devices that use plugins.
Sat Apr 16, 2022 5:15 am
@jroach added dev name as requested in this release
https://github.com/IndigoDomotics/Hue-Lights-Indigo-plugin/releases/tag/1.10.20
Sat Apr 16, 2022 7:46 am
jroach offline
Thanks Karl!!!
Sat Apr 16, 2022 8:47 am
could you try the actions,
I had to change many format statements, only tested some.
Fri Apr 22, 2022 9:14 am
jroach offline
Karl, update plugin, closed indigo and restarted. Same, no device names.
Should I add a new device to see if that makes a difference.
Screen Shot 2022-04-22 at 8.07.41 AM.png (132.85 KiB) Viewed 2787 times
Fri Apr 22, 2022 9:17 am
jroach offline
These are all Hue brand bulbs, most are color/ambiance in the attachment above
Fri Apr 22, 2022 9:20 am
jroach offline
Karl, its working!
device name shows up if I go in and change one of the parameters (saturation, brightness, Etc), save, exit and now I see the device name
Fri Apr 22, 2022 9:39 am
You have to edit and save the actions before it will update.
