Virtual "Switch" / status device
Mon Jan 31, 2022 6:27 am
anupchavda offline
Hi there.
Wondered if this was possible and wanted some guidance.
I wanted to create a virtual device that I could trigger with my wave button, so that if I press a button the virtual device would report as "on" and then if I pressed the button again it would toggle to "off".
I then want toe be able to expose this device so that I can run automations off of it.
Any ideas?
Mon Jan 31, 2022 9:43 am
Re: Virtual "Switch" / status device
What's a "wave button"?
Fri May 27, 2022 6:22 am
anupchavda offline
apologies...I didn't get a notification that someone had responded. I meant a z-wave button.
Further, I have the Tesla Plugin working well now and I wanted to expose the charge port door status as a device. indigo is able to query the charge port door status.
My workflow would be:
Z-Wave1 button is pressed and the trigger runs in Indigo to open the charge port - I want the "Charge port status" device to read from the plugin as open and mark as "On"
Z-Wave2 button is pressed and the trigger runs in Indigo to close the charge port - I want the "Charge port status" device to read from the plugin as close and mark as "Off"
How would I go about creating this virtual status switch?
Fri May 27, 2022 6:25 am
The new/refreshed Adapters plugin that’s in beta at the moment will do that.
Point it at the Charge_Port status state in my Tesla plugin and it’ll show as a Device.
