HomeSeer HS-LS100+ Leak Sensor Temp Reading is WAY off
Mon Jul 19, 2021 5:09 pm
ryanbuckner offline
I have a newly installed HomeSeer HS-LS100+ Z-Wave Plus Leak Sensor that is reporting a temperature in my basement of 30.1 C (86.2 F). Next to it I placed a an RFXCOM temp/humidity sensor reporting a temperature of 65.7 F.
It's cold in the basement. Cold. Has anyone else had issues with the temp readings on the HomeSeer?
Tue Jul 20, 2021 9:59 am
Dual offline
Re: HomeSeer HS-LS100+ Leak Sensor Temp Reading is WAY off
Mine are all accurate within a couple degrees. I have 15 here. I just checked them. One is reading a little high however it is under a main floor sink which has a water heater. One reads a little low however it is tucked in a corner in the basement under the sink where I expected near the other wall it would be cooler.
Wed Aug 04, 2021 9:45 am
ryanbuckner offline
UPDATE: I had been getting no ack for a few days for the tamper, leak, and temp Indigo device statuses.
I popped the lid off the device and pressed the buttons a few times to Re-Sync with indigo.
Magically, after a Re-Sync, the HS-LS100 started reporting the temperature in Fahrenheit (which I prefer) rather than Celsius, but still 20 degrees too high. After 24 hours, the temperature started reporting accurately. I'm not really sure what changed since my troubleshooting attempt was really just to get the device reconnected to Indigo.
