GE Solo Scene Remote
Thu May 20, 2021 4:44 pm
rgspb offline
I'm trying to setup this remote https://byjasco.com/ge-enbrighten-z-wav ... mote-white to do something simple and it's not so simple. I want to set it up so that when you press the top button my fountains come on, and when you press the bottom button the fountains turn off. All I'm able to setup is Any Command Received. I can't figure out what i'm doing wrong.
Thu May 20, 2021 5:54 pm
Re: GE Solo Scene Remote
Re-sync it in Indigo, then press both buttons a few times and copy/paste the Event Log results of everything into a reply for us.
Thu May 20, 2021 6:01 pm
rgspb offline
May 20, 2021 at 7:59:07 PM
Z-Wave Syncing - started for "Fountain Remote"
Z-Wave Error Syncing - failed
Z-Wave Error No response from "078 - Fountain Remote". Module might be asleep, or is unreachable.
Z-Wave received "078 - Fountain Remote" status update battery level 100%
Z-Wave Syncing - retrieved manufacture and model names: General Electric - 0063, Portable Remote Controller - 48433031
Z-Wave Syncing - retrieved protocol version 4.38, app version 5.11
Z-Wave Syncing - retrieved class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 21v1 72v1 73v1 59v1 5Av1 7Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 0 minutes
Z-Wave Syncing - device "078 - Fountain Remote" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
The two Bold receives are from the button up push. Button down only returned one.
Thu May 20, 2021 6:27 pm
Inside the Z-Wave configuration dialog (Interfaces->Z-Wave->Configure... menu item), turn on the Debug logging checkbox then press both buttons again a few times and copy/paste the results into a reply for us. You can then turn off the Debug checkbox if you want.
Thu May 20, 2021 6:31 pm
rgspb offline
Here you go, and thank you!
May 20, 2021 at 8:30:19 PM
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 4E 03 80 03 64 58
Z-Wave Debug . . requestBatteryLevel: node 078, level 100
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 4E 02 84 07 3C
Z-Wave Debug . . nodeAwake: node 078
Z-Wave Debug SENT requestBatteryLevel1: 01 09 00 13 4E 02 80 02 25 EC E2
Z-Wave Debug RCVD requestBatteryLevel1: 01 07 00 13 EC 00 00 03 04 (node ACK)
Z-Wave Debug waiting up to 3.0 seconds for module reply after sending request
Z-Wave Debug . . nodeAwake: inhibit count++ to 1
Z-Wave Debug . . nodeAwake: started inhibit sleep timer
Z-Wave Debug . . nodeAwake: inhibit count-- to 0
Z-Wave Debug . . nodeAwake: stopping inhibit sleep timer
Z-Wave Debug SENT goToSleep: 01 09 00 13 4E 02 84 08 24 ED EC
Z-Wave Debug RCVD packet: 01 07 00 13 ED 00 00 01 07 (hex)
Z-Wave Debug . . . . . . . : skipping battery check (next check in 717 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 4E 02 84 08 24 EE EF
Z-Wave Debug RCVD packet: 01 07 00 13 EE 00 00 01 04 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 4E 02 84 08 24 EF EE
Z-Wave Debug RCVD packet: 01 07 00 13 EF 00 00 01 05 (hex)
May 20, 2021 at 8:30:39 PM
Z-Wave Debug SENT goToSleep: 01 09 00 13 4E 02 84 08 24 F0 F1
Z-Wave Debug RCVD packet: 01 07 00 13 F0 00 00 01 1A (hex)
Tue May 25, 2021 5:48 pm
rgspb offline
Any further thoughts on this issue?
Wed May 26, 2021 7:36 pm
Sorry for the slow reply. I'll try to look into this some in the next day or two.
Wed May 26, 2021 7:39 pm
rgspb offline
Thank you!
Fri May 28, 2021 1:47 pm
I just looked at this in more detail with your Indigo sync results (event log) and the manual for the module. Unfortunately, despite the module name it doesn't appear to support either the Z-Wave Scene Activation command class or the Central Scene command class. For Indigo (or the Z-Wave Scene Controller plugin) to detect which buttons are pressed it requires the module to support one of those two command classes. We used to see multi-button modules like this years ago but in general they don't work well with 3rd party hub controllers. Most newer multi button modules support the Central Scene command class which makes it easy to detect the individual button presses (and then create Indigo Triggers for them).
Fri May 28, 2021 2:09 pm
rgspb offline
Well that’s disappointing. Thanks for clarifying this though! I’ll hang on to this for maybe a future project.
Tue Jul 27, 2021 1:06 am
I’m late to the party here.
I just looked to see if I could add support for this to the Scene Controller plugin but it’s not possible.
The remote needs directly pairing with a.n.other Zwave device that you want to control.
If you have any old/disused switches or for example a double Fibaro light-switch module where you’re only using the first input/output, you could pair this with that device, then have Indigo trigger on the on/off state of that device.
Peter
Thu Nov 04, 2021 8:30 am
R&B offline
I seem to have the same problem with a HeatIT z-button 4 controller.
copy-paste from the event log doesn't do the trick.
It works fine as a controller for physical devices (with an adress), but i can't get it to activate an action group.
Also not via the Z-wave scene controller plug-in.
Thu Nov 04, 2021 1:57 pm
Stick either a Zwave Watcher (plugin) on it, or enable Zwave debug per Matts instructions above.
Press some buttons and paste the results
Mon Nov 08, 2021 8:15 am
R&B offline
these are the results when I push the button I want to activate the action group on:
Z-Wave received "030 - Wandzender Slaapkamer 2" scene 4 (0004)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 1E 05 5B 03 39 80 04 0E
Z-Wave Debug . . sceneActivateCmd2: node 030, type: 0, scene: 4
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 1E 05 5B 03 3A 80 04 0D
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 1E 05 5B 03 3B 80 04 0C
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 1E 05 5B 03 3C 80 04 0B
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 1E 05 5B 03 3D 80 04 0A
Mon Nov 08, 2021 12:37 pm
That should work out of the box with Zwave Scene Controller.
New trigger > Zwave Scene Controller event > Scene Command Received
Pick your device in Device 1.
Leave 2-4 empty.
Button ID is 4 for the button you pressed
Action is Click.
