Time to reset z-wave controller?
Fri Mar 12, 2021 10:02 pm
dlleon offline
I've been having some issues with my Z-wave stick. Before I throw it out, I thought I might try resetting it.
I have five switches that are rock solid.
Of the 7 multi sensor units, two work, three don't report (swapped batteries in all of them), and two I can't get to sync at all.
When I try to add the new ones, they will time out. I've factory reset them, tried the exclusion, re-include with security on and off.
Any ideas?
Log below--
Z-Wave stopping controller inclusion mode
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "004 - Relay Power Switch"
Z-Wave Syncing - assigning return route to "004 - Relay Power Switch"
Z-Wave Error Syncing - failed to assign return route
Z-Wave Error No response from "004 - Relay Power Switch". Module might be asleep, or is unreachable.
failed units report
Z-Wave found failed module reported by controller "Internet 002 - Relay Power Switch"
Z-Wave found failed module reported by controller "004 - Relay Power Switch"
Z-Wave found failed module reported by controller "034 - Great Room Yellow lamp "
Z-Wave found failed module reported by controller "entryway 054 - LED Bulb (LB60Z-1)"
removing failed units does this
Z-Wave Error cannot remove failed module 002 from controller until device "Internet 002 - Relay Power Switch" is deleted
Z-Wave removing from controller failed module "004 - Relay Power Switch"
Z-Wave Error cannot remove failed module 034 from controller until device "Great Room Yellow lamp " is deleted
Z-Wave Error cannot remove failed module 054 from controller until device "entryway 054 - LED Bulb (LB60Z-1)" is deleted
Z-Wave reloading module information from controller
Z-Wave connection reset requested
Z-Wave connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodemFD1311 (firmware 1.01, minimum SDK 6.51.06)
Z-Wave found module included in controller with no matching device (missing or disabled): 005 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 014 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 024 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 026 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 027 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 028 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 029 - Dimmable Power Switch
Z-Wave Error device "Fawn Hall 031 - Motion Sensor" should be re-synced using the "Define and Sync..." button in the device edit dialog (the internal device definition has been revised)
Z-Wave Error device "Mudroom 032 - Motion Sensor" should be re-synced using the "Define and Sync..." button in the device edit dialog (the internal device definition has been revised)
Z-Wave found module included in controller with no matching device (missing or disabled): 033 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 035 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 037 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 038 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 039 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 041 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 046 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 047 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 048 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 049 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 050 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 052 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 053 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 055 - Notification Sensor
Sat Mar 13, 2021 4:35 pm
Re: Time to reset z-wave controller?
Yeah at this point before trying a replacement I'd recommend resetting the Z-Wave controller. After doing so you'll need to re-include all the modules into it (and re-sync the devices). Note the modules themselves won't be able to include into the controller until they are excluded. You can exclude them after the reset though (any controller can tell a module to exclude itself – it doesn't have to be the controller that it is actually included into). A factory reset of the modules might also exclude them if their manual has reset steps.
Matt
