- Posted on
Tue Sep 01, 2020 4:49 pm
Sharek326
offline
I removed it again noticing it didn't sync any neighbors and this last time I added it manually by using just the stick at the switch and not the built in inclusion. Better results but still not power reporting on S1
Syncing - started for "075 - Relay Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 8, 9, 10, 11, 15, 16, 19, 23, 24, 27, 29, 31, 33, 36, 37, 38, 40, 44, 46, 47, 50, 51, 52, 53, 54, 56, 65, 66
Z-Wave Syncing - assigning return route to "075 - Relay Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Dual Nano Switch (ZW132) - 01030084
Z-Wave Syncing - retrieved protocol version 4.54, app version 2.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 2Bv1 25v1 86v1 81v1 27v1 2Cv1 32v3 8Ev1 70v1 71v1 72v1 73v1 59v1 7Av1 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 59 85 8E 25 32], 2:[5E 59 85 8E 25 32]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved parameter 252 "Lock configuration" is false
Z-Wave Syncing - retrieved parameter 80 "Automatic notification" is 3
Z-Wave Syncing - device "075 - Relay Power Switch" parameter 80 "Automatic notification" changed to 2 (was 3)
Z-Wave Syncing - retrieved parameter 20 "Power up state" is 0 "Last State"
Z-Wave Syncing - retrieved parameter 120 "S1 switch mode" is 1 "2 State"
Z-Wave Syncing - retrieved parameter 121 "S2 switch mode" is 1 "2 State"
Z-Wave Syncing - retrieved parameter 122 "External switch" is 3 "Controls Load and Associations"
Z-Wave Syncing - retrieved parameter 83 "LED mode" is 0 "Mirrors Load"
Z-Wave Syncing - retrieved parameter 3 "Current overload protection" is true
Z-Wave Syncing - retrieved parameter 4 "Over heat protection" is false
Z-Wave Syncing - retrieved parameter 90 "Enable energy change reports" is false
Z-Wave Syncing - retrieved parameter 91 "Report threshold watts" is 25 watts
Z-Wave Syncing - retrieved parameter 92 "Report threshold percentage" is 5 %
Z-Wave Syncing - retrieved parameter 111 "Reporting interval" is 10 seconds
Z-Wave Syncing - device "075 - Relay Power Switch" parameter 111 "Reporting interval" changed to 600 seconds (was 10 seconds)
Z-Wave Syncing - retrieved parameter 112 "Reporting interval2" is 600 seconds
Z-Wave Syncing - device "075 - Relay Power Switch" parameter 112 "Reporting interval2" changed to 600 seconds (was 600 seconds)
Z-Wave Syncing - retrieved parameter 113 "Reporting interval3" is 600 seconds
Z-Wave Syncing - device "075 - Relay Power Switch" parameter 113 "Reporting interval3" changed to 600 seconds (was 600 seconds)
Z-Wave Syncing - retrieved parameter 101 "Group 1 flags" is 0
Z-Wave Syncing - device "075 - Relay Power Switch" parameter 101 "Group 1 flags" changed to 6915
Z-Wave Syncing - retrieved parameter 102 "Group 2 flags" is 0
Z-Wave Syncing - device "075 - Relay Power Switch" parameter 102 "Group 2 flags" changed to 0
Z-Wave Syncing - retrieved parameter 103 "Group 3 flags" is 0
Z-Wave Syncing - device "075 - Relay Power Switch" parameter 103 "Group 3 flags" changed to 0
Z-Wave Syncing - synced server clock to module (18:46, Tuesday)
Z-Wave Syncing - changed device "069 - Both Switches" address from undefined to 075
Z-Wave Syncing - changed device "Whole House Fan (Switch 1)" address from undefined to 075
Z-Wave Syncing - changed device "Master Fan (Switch 2)" address from undefined to 075
Z-Wave Syncing - complete
Z-Wave sent "069 - Both Switches" status request
Z-Wave sent "069 - Both Switches" energy status request
Z-Wave sent "Whole House Fan (Switch 1)" status request
Z-Wave sent "Whole House Fan (Switch 1)" energy status request
Z-Wave sent "Master Fan (Switch 2)" status request
Z-Wave sent "Master Fan (Switch 2)" energy status request
Z-Wave received "Master Fan (Switch 2)" energy total to 0.883 kWh
Z-Wave received "Master Fan (Switch 2)" power load to 64.614 W
Z-Wave received "069 - Both Switches" energy total to 0.884 kWh
Z-Wave received "069 - Both Switches" power load to 64.493 W
