Our house HVAC is being updated. I will be using the Honeywell T6 Pro (z-wave, if that makes a difference). The thermostats haven't arrived yet but I want to get started prepping indigo.
Reading through the Honeywell info I see two apps; Total Connect Comfort and Honeywell Home app. I also have heard that the Mr.Slim plug-in is also needed.
Do I need either of the Honeywell apps these if I plan to use Indigo to operate the units? I still want thermostat control, set temp higher/lower at each of thermostats if possible (I heard something about the controls at the thermostat are not usable if connected to a hub (hub=zwave and indigo?)
