aotec nanomote button pressed trigger
Wed Nov 06, 2019 1:05 am
wamartei offline
triggers only seem to be giving me access to "battery_level" for the nannomote. How can I make triggers from "button pressed"
Wed Nov 06, 2019 9:36 am
Re: aotec nanomote button pressed trigger
Are you choosing the Trigger Type Z-Wave Command Received, then selecting Incoming Command Received from Device?
Wed Nov 06, 2019 10:05 am
wamartei offline
no, wasn't doing that,, will try later when i get home, thanks!
Thu Jan 21, 2021 2:40 pm
norcoscia offline
I just added one of these - I set it up and indigo sees it but does not see the button press - info below
Indigo Z-Wave Version: 7.5.0
Node ID: 66
Model: NanoMote Quad (ZWA003)
Model ID: 01020003
Manufacturer: Aeon Labs
Manufacturer ID: 0371
Protocol Version: 4.61
Application Version: 1.03
Model Definition Version: 1
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 55v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 20v1 6Cv1 70v1 72v1 73v1 7Av1
Encryption Status: Enabled for Commands 80 84 85 86 59 5A 5B 70 72 73 7A
Features: routing, battery, beaming, security, waking
Neighbors: 2, 3, 4, 5, 6, 7, 8, 9, 12, 14, 18, 19, 20, 21, 22, 25, 26, 31, 32, 33, 34, 46, 47, 48
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[] 7:[] 8:[] 9:[]
Config Values: 41:0 43:0
Is this a new config that indigo does not support yet - help!!!!!!
PS - yes I'm choosing the Trigger Type Z-Wave Command Received, and then selecting Incoming Command Received from Device.
_______
Norm
Thu Jan 21, 2021 3:01 pm
norcoscia offline
So I excluded it and re-did the define and sync and got a little different message (with some errors) - still does not work
Jan 21, 2021 at 12:52:24 PM
Z-Wave started controller inclusion mode with encryption
Jan 21, 2021 at 12:52:45 PM
Z-Wave controller included module: 067 - Basic Wall Controller
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "067 - Basic Wall Controller"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 9, 12, 14, 18, 19, 20, 21, 22, 25, 26, 31, 32, 33, 34, 46, 47, 48, 64
Z-Wave Syncing - assigning return route to "067 - Basic Wall Controller"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0371, NanoMote Quad (ZWA003) - 01020003
Z-Wave Syncing - retrieved protocol version 4.61, app version 1.03
Schedule Update clock
Z-Wave received "Garage Door Controller 2 Door (NGD00Z) - 034" status update is closed
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 55v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 20v1 6Cv1 70v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: 80 84 85 86 70 72 73 59 5A 5B 7A
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 0 minutes
Z-Wave Syncing - device "067 - Basic Wall Controller" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Syncing - retrieved group 9 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - module returned parameter 32 instead of parameter 41 "Enable scene commands" (ignoring)
Z-Wave Syncing - failed to retrieve parameter 41 "Enable scene commands" (skipping)
Z-Wave Syncing - retrieved parameter 43 "Enable low battery buzzer" is false
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - changed device "066 - NanoMote Quad (ZWA003) Garage Door Remote" address from undefined to 067
Z-Wave Syncing - complete
Z-Wave device "067 - 066 - NanoMote Quad (ZWA003) " parameter 41 "Enable scene commands" changed to false
_______
Norm
Sat Jan 23, 2021 7:05 pm
Hi Norm,
For it to work the Enable scene commands option in the device settings dialog needs to be enabled. From your Event Log snippet above, it looks like that isn't the case maybe?
Sun Jan 24, 2021 10:24 am
norcoscia offline
It would not let me change it - so I factory reset the quad and trashed all the indigo stuff I had and started over fresh.
The new add info below - I was able to turn on scene commands but it is still not working - when I press any button indigo does not seem to get / see any Z-wave commands - I'm very confused at this point :-(
Jan 24, 2021 at 8:07:52 AM
Z-Wave controller included module: 068 - Basic Wall Controller
Z-Wave Syncing - started for "068 - Basic Wall Controller"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 9, 12, 14, 19, 20, 21, 22, 25, 26, 31, 32, 33, 34, 46, 47, 48
Z-Wave Syncing - assigning return route to "068 - Basic Wall Controller"
Z-Wave Syncing - device "068 - Basic Wall Controller" wake interval changed to 60 minutes
Z-Wave Syncing - created device "068 - NanoMote Quad (ZWA003)"
SQL Logger creating table device_history_490983781 for "068 - NanoMote Quad (ZWA003)"
SQL Logger adding column "batterylevel_ui" to table device_history_490983781 ("068 - NanoMote Quad (ZWA003)")
Z-Wave device "068 - NanoMote Quad (ZWA003)" parameter 41 "Enable scene commands" changed to false
Z-Wave device "068 - NanoMote Quad (ZWA003)" parameter 41 "Enable scene commands" changed to true
_______
Norm
Sun Jan 24, 2021 3:50 pm
It looks like the firmware version you have does not support parameter #41. The one I have does, but it is a beta unit Aeotec sent me so it has an older firmware version. Additionally, the engineering docs do not mention parameter #41 (unlike the NanoMote One which does have it).
I'll remove the UI for that parameter from the next version of Indigo so that it doesn't try to read out that value when syncing. However, I don't believe this will fix the problem you are seeing. From my understanding this module should always send the central scene commands which Indigo is using for the Triggers.
Let's debug into this some more. Turn on Indigo's Z-Wave Debug Logging checkbox via the Interfaces->Z-Wave->Configure... menu item. Next, press all of the buttons on the remote individually, waiting about 5 seconds between each press. Copy/paste the Event Log results into a reply for me so we can see what commands are being sent (if any).
Sun Jan 24, 2021 5:08 pm
norcoscia offline
Nothing in the log when I press any of the buttons but I do see this (below) - which looks to be the prior nanomote ID (067) that I removed - 068 is the current nanomote ID. Not sure why it seems to do nothing when I press any of the buttons but it does seem to be reporting the battery every hour and it updated my setting when I turned on scene commands?
Any idea what I can try?
Jan 24, 2021 at 3:01:35 PM
Z-Wave connection reset requested
Z-Wave connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14601 (firmware 1.00, SDK unknown)
Z-Wave found module included in controller with no matching device (missing or disabled): 067 - Basic Wall Controller
Edit -- Should I try adding it w/o encryption?
_______
Norm
Sun Jan 24, 2021 6:17 pm
Yes, definitely try without encryption (exclude it first). I didn't catch you had included it with encryption before. I suspect it will work fine without it.
Sun Jan 24, 2021 6:38 pm
norcoscia offline
Yup - works w/o encryption - Thanks!!!!
BTW, how to I get rid of one of the old ID for it that looks like it is still in my z-wave stick - see below?
_______
Norm
Mon Jan 25, 2021 2:24 am
CliveS offline
Look at
viewtopic.php?p=197769#p197769
CliveS
Mon Jan 25, 2021 9:58 am
norcoscia offline
Thanks but I have other modules that fail but I don't want to remove them (they are only plugged in when / if needed - would like to just remove ID 67 not any of the others.....
_______
Norm
Mon Jan 25, 2021 10:09 am
That isn't currently possible. Indigo only has UI for removing all failed nodes. I'll add to the feature request adding more granular control.
Mon Jan 25, 2021 10:33 am
norcoscia offline
OK, thanks for all the help and stay safe!
_______
Norm
