Anyone Using Switchbot?
Wed Oct 23, 2019 2:10 pm
sdmike offline
Curious if anyone has any experience with Switchbot hardware and incorporating it into Indigo.
It looks like it works with Alexa, Google Home, Siri, and IFTTT. They will be releasing an interesting piece of hardware in about 6 months to retrofit existing drapes for remote operation.
https://9to5toys.com/2019/10/22/switchb ... ore-522266
I suppose I could work it through Alexa, though recent events have shown that's not necessarily a permanent solution, at least until there is deeper support for Alexa in Indigo.
Wed Oct 23, 2019 2:29 pm
Re: Anyone Using Switchbot?
Note that even with a full Indigo Alexa Skill, this likely isn't going to be possible. Skills for one product don't have direct access to things provided by other skills (even if they are both smart home skills). If they have an API, that would be the best option.
Fri Feb 19, 2021 8:55 am
Different Computers offline
Anyone who has found ways to integrate this with Indigo? I note that the switchbot hub works with Siri *shortcuts* but not directly with HomeKit, so unless I'm missing a step I don't see how HomeKit Bridge would help here.
I'm super disappointed with every garage door control option out there, and a switch bot would work for me. But I really want it in Indigo too.
Fri Feb 19, 2021 10:59 am
They have the API specification and some code on GitHub: https://github.com/OpenWonderLabs
The basic API is via the cloud service. You could probably get simple automations working in Indigo via the GhostXML plugin or some very simple Python scripts.
For local control (no cloud) they have code that will run on an rPi with a bluetooth dongle.
They also have some home-bridge plugins.
Fri Feb 19, 2021 11:18 am
For example, this code will get the list of devices and print it to the log. You would need to get the token using their mobile app per the API instructions.
import requests
token_header = {'Authorization': token}
base_url = "http://https://api.switch-bot.com/v1.0"
url = base_url + "/devices"
resp = requests.get(url, headers=token_header)
indigo.server.log(u"get /devices, resp = {}".format(resp.json))
Fri Feb 19, 2021 12:46 pm
Users browsing this forum: No registered users and 18 guests
