Three dry contacts
Fri Sep 06, 2019 7:40 am
zoff offline
Three dry contacts
I'm looking for a Z-wave device with at least 3 dry contacts for a DIY irrigation system. So far I see that I can order 3 Qubino 1d replays but that gets expensive. Is there another device that you can recommend that has indigo support too.
TIA
Fri Sep 06, 2019 8:45 am
Dual offline
Re: Three dry contacts
Have you searched here:
https://products.z-wavealliance.org/reg ... categories
Fri Sep 06, 2019 12:24 pm
zoff offline
Thanks, thats a useful link but I'd like to also get Indigo compatibility and user comments.
Fri Sep 06, 2019 3:13 pm
mclass offline
Arduino with relay shield in conjunction with Karl’s excellent Arduino plug in?
https://store.arduino.cc/usa/4-relays-shield
Sat Sep 07, 2019 8:46 am
zoff offline
Thanks but it looks like a steep learning curve. I've never used Arduino and checked out the link and there is too much I don't understand. I already went down the Sonoff 4CH route and gave up
Thu Sep 12, 2019 7:01 pm
agame offline
not zwave, but with good indigo integrations:
https://forums.indigodomo.com/viewtopic.php?t=21875&p=172116
or
https://www.globalcache.com/products/flex/
I'm using the 8 channel relay for irrigation, with success.
Fri Sep 13, 2019 6:37 am
mundmc offline
or
+1
I am using the 8 channel relay to control an actuator that opens my bar window. It replaced an insteon IOLinc and a DPDT relay.
Sat Sep 14, 2019 9:41 am
zoff offline
Thanks! This looks pretty straight forward.
Sun Sep 15, 2019 11:50 am
jaga01 offline
HI,
Did you look into the FIbaro Smart Implant FGBS-222. It should work with indigo. It build for stuff like that :D
Look here:
https://www.fibaro.com/en/products/smart-implant/
Regards, Jacob
