USB Controller not connecting
Mon Jul 01, 2019 5:57 pm
dprlemon offline
Hi There. I just upgraded my iMac from a 2011 model to the new 2019. My 2011 model used to have issues with the PowerLink 2413U not connecting after a power outage. I read that was an issue with older Macs, so I accepted it. But now I'm having a worse problem connecting with my new iMac. When I reboot or startup it will not connect. Sometimes unplugging and replugging in the USB cable will solve it, sometimes not. Quitting the application and relaunching will work and sometimes I have to reboot. The version of the PowerLink is 2.1, 1621. Any suggestions?
Tue Jul 02, 2019 9:29 am
Re: USB Controller not connecting
What exactly are the errors you see in the Event Log when it fails to reconnect?
Also, is it plugged directly into a USB port on your Mac? Have you tried a different USB cable?
Finally, when it does finally connect, do you see any Insteon errors in the event log (no acks, etc)?
Tue Jul 02, 2019 5:09 pm
dprlemon offline
Below is the log showing the errors and then when it connected. Yes, it's plugged directly into my Mac's USB port and yes, I have tried a different cable with same results. It connected once I switched ports. It killed the port it was originally connected to - had to switch my Logitech fob to another port to get my keyboard reconnected. See log entry at bottom.
Jul 1, 2019 at 6:05:32 PM
Interface Failure failed to establish connection with serial interface PowerLinc Modem on port usbserial-A600B23S
Jul 1, 2019 at 6:07:26 PM
Closed connection to PowerLinc Modem
Disabling interface "INSTEON Commands 2.2.2"
Stopping interface "INSTEON Commands 2.2.2" (pid 702)
Stopped interface "INSTEON Commands 2.2.2"
Enabling interface "INSTEON Commands 2.2.2"
Starting interface "INSTEON Commands 2.2.2" (pid 921)
Started interface "INSTEON Commands 2.2.2"
Jul 1, 2019 at 6:08:16 PM
Connected to PowerLinc 2413U interface on port usbserial-A600B23S
PowerLinc address 41.EC.C5, firmware version 9.14
Jul 1, 2019 at 6:09:20 PM
Received INSTEON "Office Motion" on (button 1)
Jul 1, 2019 at 6:10:46 PM
Received INSTEON "Office Motion" off (button 1)
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Jul 2, 2019 at 5:55:49 PM
Power Failure possible power failure
Jul 2, 2019 at 5:56:42 PM
Interface Failure failed to establish connection with serial interface PowerLinc 2413U on port usbserial-A600B23S
Jul 2, 2019 at 5:58:19 PM
Closed connection to PowerLinc 2413U
Stopping interface "INSTEON Commands 2.2.2" (pid 921)
Starting interface "INSTEON Commands 2.2.2" (pid 24400)
Jul 2, 2019 at 6:01:02 PM
Stopping interface "INSTEON Commands 2.2.2" (pid 24400)
Jul 2, 2019 at 6:01:29 PM
Starting interface "INSTEON Commands 2.2.2" (pid 24464)
---Switched ports
Jul 2, 2019 at 6:02:09 PM
Tue Jul 02, 2019 6:44 pm
I don't understand what that means...
Wed Jul 03, 2019 4:43 am
dprlemon offline
I switched ports with the controller and keyboard. The controller connected but my keyboard stopped working - the port was dead.
This doesn't sound like a common problem with Indigo or the controller. I'm thinking it might be related to another USB device or one of the 2 hubs I have connected (the keyboard was acting sporadic when connected to one of the hubs). I'm going to troubleshoot it from that perspective and if I still have issues I'll get back to you. Thanks, Jay.
Wed Jul 03, 2019 4:34 pm
dprlemon offline
Well, Jay, I thought that was the issue but apparently not. I shut down, I unplugged all the USB devices rebooted and the controller still wouldn't connect. Unplugging the USB cable from the controller, quitting Indigo, plugging the controller back in and relaunching Indigo, seemed to work. Could there be something wrong with the controller itself? Below is the entire startup process:
Jul 3, 2019 at 5:24:37 PM
Starting Indigo Server version 7.3.1 (Mac OS X 10.14.5)
Loading attachments
Loading database "/Users/dan_rosellini/Documents/Indigo Home Automation/My House 01.22.16.indiDb"
Loading plugin "Masquerade 0.1.5"
Starting plugin "Masquerade 0.1.5" (pid 642)
Loading plugin "Foscam HD Controller 2.3.1"
Starting plugin "Foscam HD Controller 2.3.1" (pid 643)
Loading interface "INSTEON Commands 2.2.2"
Starting interface "INSTEON Commands 2.2.2" (pid 644)
Loading plugin "Action Collection 2.1.5"
Starting plugin "Action Collection 2.1.5" (pid 645)
Found disabled plugin "DIRECTV DVR Control 1.1.1"
Found disabled plugin "Growl 2.0.2"
Found disabled interface "Z-Wave 2.0.124"
Found disabled interface "Virtual Devices 2.0.5"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Vera Bridge 1.0.10"
Found disabled plugin "Timers and Pesters 2.0.2"
Found disabled plugin "Airfoil Pro 1.0.9"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "SQL Logger 2.1.0"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "HomeKit Bridge 1.0.2"
Found disabled plugin "Airfoil 1.1.14"
Found disabled plugin "WeatherSnoop 3.0.0"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Bonjour registered "Indigo - My House 01.22.16"
Indigo Cocoa client connected
Started plugin "Masquerade 0.1.5"
Masquerade Starting Masquerade
Foscam HD Controller Autolog 'Foscam HD Controller' initializing . . .
Started plugin "Action Collection 2.1.5"
Foscam HD Controller Warning Monitoring enabled for Foscam HD: Send, Receive
Foscam HD Controller Warning Debugging enabled for Foscam HD: Send, Method Trace, Polling
Started plugin "Foscam HD Controller 2.3.1"
Foscam HD Controller Autolog 'Foscam HD Controller' initialization complete
Foscam HD Controller Initialised 'ThreadPolling' Thread for Entry Camera [10.0.1.7:88] to poll at 60 second intervals
Foscam HD Controller Initialised 'ThreadPolling' Thread for Family Room Camera [10.0.1.53:89] to poll at 60 second intervals
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Foscam HD Controller 'Family Room Camera' camera time synchronised to '2019-07-03 22:24:42 PM UTC -5'
Jul 3, 2019 at 5:24:43 PM
Foscam HD Controller 'Entry Camera' camera time synchronised to '2019-07-03 22:24:44 PM UTC -5'
Indigo Cocoa client disconnected
Jul 3, 2019 at 5:25:34 PM
Jul 3, 2019 at 5:25:52 PM
Jul 3, 2019 at 5:26:12 PM
Wed Jul 03, 2019 5:47 pm
Could be. First, disable all 3rd party plugins and let's see if that makes any difference. Unlikely, but we've seen odd interactions before.
