I have a lamplinc that however it is switched off a few seconds later it turns back on. I have reviewed the Events folder and watched the event log after I turn off the lamplinc, but I don't understand what exactly it is telling me in the log. See attached log. Any ideas. And yes I replaced the module with a brand new one and it does the same thing. So apparently the command is coming from something in my Indigo data base. Just don't know what.
I got this initial response from Matt:
"That is a pretty strange one. I would say the module is malfunctioning, but if a replacement module responds exactly the same way that seems very unlikely. Generally, Indigo always logs commands it sends via Insteon, but just to make sure the command to turn it back On isn't originating from Indigo let's turn on Indigo's debug logging. To do so hold down the Option+Shift keys while choosing the Indigo 7->Preferences... menu item. Select the General tab panel then enable the "LLIO" checkbox option. Finally, repeat the steps you did before. Indigo will show its lower level debug logging, which will definitely include any commands it is sending. Let's see what that turns up and go from there."
