Fxguy wrote:Jay,
I did move the server at one point, but that was quite some time ago and its been running on the current Mac for a while. IF it were, what would it look like in the Activity Monitor just to make sure?
I also noticed that it seems to be happening when I am connected to my local wifi network. If I'm away from home or not connected, it logged in and worked fine. Its only when I'm at home that there seems to be a problem. Perhaps something to do with Bonjour?
I'd recommend this: in Indigo Touch while on your local network, delete all the connections in the settings dialog. Close it, then reopen it. If you see multiple entries, then there are definitely 2 servers running on separate Macs on your network. On the one(s) that aren't supposed to be running Indigo, you can
follow the directions to remove Indigo and reboot (those files just won't be there if Indigo isn't installed there).
