Trigger Device Options Not Showing
Thu Jul 12, 2018 7:39 pm
ckeyes888 offline
Have an issue triggering from an X10 remote button device.
I have a number of others defined the exact same way that do show it’s options when setting up a trigger.
Any idea why the device settings won’t show?
Carl
Fri Jul 13, 2018 9:49 am
Re: Trigger Device Options Not Showing
X10 remotes (as well as Insteon remotes) don't have states like switches do. You have to trigger off the X10 command received from the remote, not from a state change.
Fri Jul 13, 2018 8:51 pm
ckeyes888 offline
Thanks. I did eventually figure that out. What had me going on it was I did have a number of X10 PalmPad button
devices that did show device options in triggers.
I recently reinstalled Indigo after a server change and the options disappeared.
Triggering from device state changes actually worked much better than X10 signal received in that
the particular buttons I’m using always send a number of commands, on and a number of brightens,
on each button press.
Triggering from it’s state simply becoming on kept it from multiple triggers from one press.
Edit: What I ended up doing, which works fine, is defining the button as an appliance module.
Carl
Sat Jul 14, 2018 8:18 am
Odd, we haven't touched the X10 code and UI in about 8 years...
