Trigger Device Options Not Showing
Posted:
Thu Jul 12, 2018 7:39 pm
by ckeyes888
Have an issue triggering from an X10 remote button device.
I have a number of others defined the exact same way that do show it’s options when setting up a trigger.
Any idea why the device settings won’t show?
Carl
Re: Trigger Device Options Not Showing
Posted:
Fri Jul 13, 2018 9:49 am
by jay (support)
X10 remotes (as well as Insteon remotes) don't have states like switches do. You have to trigger off the X10 command received from the remote, not from a state change.
Posted:
Fri Jul 13, 2018 8:51 pm
by ckeyes888
Thanks. I did eventually figure that out. What had me going on it was I did have a number of X10 PalmPad button
devices that did show device options in triggers.
I recently reinstalled Indigo after a server change and the options disappeared.
Triggering from device state changes actually worked much better than X10 signal received in that
the particular buttons I’m using always send a number of commands, on and a number of brightens,
on each button press.
Triggering from it’s state simply becoming on kept it from multiple triggers from one press.
Edit: What I ended up doing, which works fine, is defining the button as an appliance module.
Carl
Posted:
Sat Jul 14, 2018 8:18 am
by jay (support)
Odd, we haven't touched the X10 code and UI in about 8 years...
