How to see if device is included with or without encryption?
PostPosted: Wed Apr 18, 2018 10:14 am
by Frakke
Hi All,
Can I somehow see if a device is added with or without encryption?
Regards
Re: How to see if device is included with or without encrypt
PostPosted: Wed Apr 18, 2018 10:31 am
by Colorado4Wheeler
I believe if the 'zwEncryptClassCmdMap' property is populated then it is:
indigo.server.log(unicode(indigo.device[YOUR_DEVICE_ID].ownerProps))
PostPosted: Wed Apr 18, 2018 10:51 am
by Frakke
Hmm, i'm gettings this error:
mbedded script: 'DeviceCmds' object does not support indexing
PostPosted: Wed Apr 18, 2018 10:59 am
by DaveL17
Typo fixed here. Device should be devices.
indigo.server.log(unicode(indigo.devices[YOUR_DEVICE_ID].ownerProps))
PostPosted: Wed Apr 18, 2018 11:01 am
by Frakke
Yes, then I'm gettings this one?
embedded script: 'key id 42 not found in database'
42 is the address of a Z-Wave device.
PostPosted: Wed Apr 18, 2018 11:08 am
by DaveL17
You should use the Indigo device ID, which is found by right-clicking on said device -- instead of the Z-Wave node ID which it seems like you're using. :D
PostPosted: Tue Apr 24, 2018 12:56 am
by Frakke
Yes.. :roll:
I think it's this one:
 zwEncryptionStatusStr : Supported but not Enabled (string)
PostPosted: Tue Apr 24, 2018 3:30 am
by DaveL17
According to C4W above, you should examine 'zwEncryptClassCmdMap'. What is the value of that property?
PostPosted: Tue Apr 24, 2018 3:36 am
by Frakke
Nothing useful i'm afraid:
zwEncryptClassCmdMap : (dict)
So, I think this one is the correct one:
PostPosted: Tue Apr 24, 2018 5:37 am
by DaveL17
I don't have any encrypted devices, but it looks like that one is not added with encryption.
PostPosted: Tue Apr 24, 2018 8:33 am
by Colorado4Wheeler
I was replying to the question as to if it had been added with or without encryption, if zwEncryptClassCmdMap is empty then it's not currently encrypted, but zwEncryptionStatusStr shows that it can be.
PostPosted: Tue Apr 24, 2018 4:25 pm
by matt (support)
That is correct. Here is a slightly preferred technique (less likely to break in the future) to get both states:
supportEncryption = "c152" in dev.ownerProps["zwClassCmdMap"]
usingEncryption = len(dev.ownerProps["zwEncryptClassCmdMap"]) > 0
