Nano Switch (ZW139) Delays Status Update
Thu Apr 05, 2018 8:02 am
Sharek326 offline
As a fix for a Whirlpool controller gone bad I installed a Nano Switch (ZW139) to control the On/Off of the motor. But from time of key press (even in Indigo directly) to execution it seems to hang sending the request. Often if I send the status request it will then execute. I Optimized the network, tried syncing again but seems to have that problem continue.
Any suggestions or ideas I can try?
Update: I do see this in the log often.
Apr 5, 2018, 10:16:57 AM
Z-Wave received "Foyer Motion" status update is on
Z-Wave Error no nonce reply (066) for requestRelayStatus (re-sending)
Z-Wave received "Whirlpool" status update is off
Z-Wave sent "Whirlpool" status request
Thu Apr 05, 2018 8:55 am
Sharek326 offline
Re: Nano Switch (ZW139) Delays Status Update
Removing the device completely and adding it back in without encryption seems to have worked. No delays
Thu Apr 05, 2018 12:15 pm
Encryption greatly increases the number of messages that have to be passed around for a single event. I've noticed in general as well that there seems to be more failure/bugs when encryption is enabled (that tends to vary based on the device, as most of the locks seem to be pretty reliable). Point being, what you saw doesn't surprise me. :|
