Lightwave RF Low Battery Symptoms - In case it helps someone
Thu Apr 05, 2018 4:06 am
noel1983 offline
Hi all,
So after an hour of trying to diagnose the issue with one of my LWRF wireless switches including removing devices from Indigo and re-adding them I found the cause.
A low but not dead battery!
In case it helps someone in the future:
Symptom: Grumpy wife caused by LWRF wireless switch buttons not having the expected result.
Pressing the buttons made the light on the switch light up but the full command wasn't received by Indigo. Just a single string not the house code and unit code lines.
Solution: Change the battery!!
Lesson learned: Sometimes its the really simple things not the complicated ones! :)
Sat Apr 07, 2018 3:21 pm
Re: Lightwave RF Low Battery Symptoms - In case it helps som
Yeah I went mad trying to work out something like that with a masterswitch. I even replaced the battery.. but ironically the battery I replaced it with was also low and caused the same issue.
