Virtual Devices not Enabled
Thu Jan 18, 2018 12:28 pm
zurich offline
Greetings,
I am try to create a Virtual Device. I select NEW/TYPE and Virtual Device is greyed out. I select INTERFACES and Virtual Device has no menu (no arrow).
Can you assist please?
Kind regards,
Z
Thu Jan 18, 2018 12:38 pm
Re: Virtual Devices not Enabled
You need to enable the interface in Indigo Preferences > Interfaces :)
Fri Jan 19, 2018 7:41 am
zurich offline
Greetings autolog,
I do not have a selection for Virtual Devices in Preferences/Interfaces. I only have Z-Wave, INSTEON/X10 Power Line Interface and X10 RF Interface. There is no option for Virtual Devices.
Any other ideas?
kind regards,
Z
Fri Jan 19, 2018 8:25 am
What version of Indigo are you running?
Fri Jan 19, 2018 9:43 am
Presuming you are running Indigo 7, download and re-run the latest installer and restart the Mac. It sounds like your install of Indigo might have become corrupt.
Sat Jan 20, 2018 5:22 am
zurich offline
Greetings,
Actually I am still run Indigo 6.1.11.
kind regards,
Z
Sat Jan 20, 2018 6:08 am
Then do what Matt suggests but for Indigo 6 :)
Take a look at the Indigo 6 documentation here: Virtual Devices Interface
That states that you should follow the procedure I previously noted. :)
Tue Jan 23, 2018 7:46 am
Downloads for 6 and 7:
https://www.indigodomo.com/downloads.html
Thu Oct 26, 2023 2:56 pm
rsaye offline
I am running version 2023.1 & 2022.2 at different locations and "Virtual Devices" is greyed out. Does anyone know how to resolve this?
Ronnie
Thu Oct 26, 2023 4:05 pm
Have you tried what autolog suggested in post 2, or Matt suggested in post 5?
Peter
Fri Oct 27, 2023 8:31 am
rsaye offline
Yes tried to reinstall with same results. "Virtual Devices" is greyed out under interfaces menu.
Screenshot 2023-10-27 at 9.28.39 AM.png (272.37 KiB) Viewed 923 times
Ronnie
Fri Oct 27, 2023 9:10 am
Questions:
1) What macOS version are you using?
2) What is the model of Mac?
3) Are there any errors in the Event Log window when you restart the server (copy/paste into Code tags if there are)
4) Both locations, running different versions, have the same issue (when using the Indigo Mac client on each computer)?
Fri Oct 27, 2023 9:59 am
rsaye offline
One Mac running Monterey 12.7 on Mac mini (Late 2014) 2.8 GHz Dual-Core Intel Core i5 8 GB 1600 MHz DDR3 --- Indigo 2022.2
One Mac running Sonoma 14.1 on Mac mini (2018) 3 GHz 6-Core Intel Core i5 16 GB 2667 MHz DDR4 --- Indigo 2023.1
No errors in the log
Correct. Same greyed out option for Virtual Devices.
Ronnie
Fri Oct 27, 2023 10:33 am
After a server restart, copy/paste the entire contents of the event log window into Code tags in a reply.
Also, are you running under the same user account (that has admin privileges) that installed it with?
Fri Oct 27, 2023 10:42 am
rsaye offline
Yes same admin user account
Oct 27, 2023 at 11:39:39 AM
   Starting Indigo Server version 2022.2.2 on macOS Version 12.7 (Build 21G816)
   Loading database "/Users/administrator/Documents/Office.indiDb"
   Waiting for client to connect
   Retrieved unchanged location for sunset/sunrise calculation
   Indigo Cocoa client connected
   Waiting for client to sync
   Finding disabled plugins
   Found disabled plugin "MQTT Broker 2022.1.0" using API v3.0
   Found disabled plugin "Hubitat Bridge 2022.0.9" using API v3.0
   Found disabled interface "INSTEON Commands 2022.2.1" using API v3.0
   Loading internal plugins
   Loading interface "Z-Wave 2022.2.1" using API v3.0
   Starting interface "Z-Wave 2022.2.1" (pid 43009)
   Loading plugin "Web Server 2022.2.0" using API v3.0
   Starting plugin "Web Server 2022.2.0" (pid 43010)
   Loading plugin "Action Collection 2022.2.0" using API v3.0
   Starting plugin "Action Collection 2022.2.0" (pid 43011)
   Loading plugin "Vera Bridge 2.2.0" using API v2.0
   Starting plugin "Vera Bridge 2.2.0" (pid 43012)
   Started plugin "Action Collection 2022.2.0"
   Started interface "Z-Wave 2022.2.1"
   Z-Wave                          connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14701 (firmware 1.00, SDK unknown)
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 003 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 004 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 005 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 006 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 007 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 008 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 009 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 010 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 011 - Basic Repeater Slave
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 012 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 013 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 015 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 016 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 017 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 020 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 022 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 024 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 025 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 027 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 029 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 030 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 032 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 037 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 044 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 050 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 051 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 055 - General Thermostat (v2)
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 057 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 059 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 063 - General Thermostat (v2)
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 068 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 069 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 070 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 073 - Keypad Door Lock
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 074 - Keypad Door Lock
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 075 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 076 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 077 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 078 - Keypad Door Lock
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 079 - Relay Power Switch
   Started plugin "Vera Bridge 2.2.0"
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 084 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 087 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 088 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 091 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 093 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 094 - Keypad Door Lock
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 100 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 101 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 105 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 113 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 116 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 126 - Secure Barrier Add-On
   Started plugin "Web Server 2022.2.0"
   Web Server                      starting internal Web server on http://localhost:8176
   Waiting for internal plugins to initialize
   Bonjour registered "Indigo - Office"
   Reflector                       starting reflector connection to https://tes.indigodomo.net
   Loading external plugins
   Loading plugin "Cynical Behaviors 3.1.0" using API v3.0.0
   Starting plugin "Cynical Behaviors 3.1.0" (pid 43031)
   Loading plugin "Z-Wave Interpreter 2022.0.0" using API v3.0
   Starting plugin "Z-Wave Interpreter 2022.0.0" (pid 43032)
   Loading plugin "DSC Alarm 2022.0.6" using API v3.0
   Starting plugin "DSC Alarm 2022.0.6" (pid 43033)
   Loading plugin "Virtual Garage Door 1.2.1" using API v3.0
   Starting plugin "Virtual Garage Door 1.2.1" (pid 43034)
   Loading plugin "HomeKitLink Siri 0.6.5" using API v3.2
   Starting plugin "HomeKitLink Siri 0.6.5" (pid 43035)
   Started plugin "Virtual Garage Door 1.2.1"
   Z-Wave Interpreter
============================================= Initialising Z-Wave Interpreter Plugin =============================================
Plugin Name:                    Z-Wave Interpreter
Plugin Version:                 2022.0.0
Plugin ID:                      com.autologplugin.indigoplugin.zwaveinterpreter
Indigo Version:                 2022.2.2
Indigo License:                 ActiveSubscription
Indigo API Version:             3.2
Architecture:                   x86_64
Python Version:                 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
Mac OS Version:                 12.7
   Z-Wave Interpreter              Indigo Event Log set to 'Debugging'
   Z-Wave Interpreter              Plugin Log set to 'No Z-Wave Logging'
   Started plugin "Z-Wave Interpreter 2022.0.0"
   Cynical Behaviors               API version 3.2
   Cynical Behaviors               Python version 3.10.2.final.0
   Started plugin "DSC Alarm 2022.0.6"
   Started plugin "Cynical Behaviors 3.1.0"
   HomeKitLink Siri
   HomeKitLink Siri                ================================================ Initializing New Plugin Session =================================================
   HomeKitLink Siri                Plugin name:                   HomeKitLink Siri
   HomeKitLink Siri                Plugin version:                0.6.5
   HomeKitLink Siri                Plugin ID:                     com.GlennNZ.indigoplugin.HomeKitLink-Siri
   HomeKitLink Siri                Indigo version:                2022.2.2
   HomeKitLink Siri                Python version:                3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
   HomeKitLink Siri                Python Directory:              /Library/Frameworks/Python.framework/Versions/3.10
   HomeKitLink Siri
   HomeKitLink Siri                ================================================== End Initializing New Plugin  ==================================================
   Started plugin "HomeKitLink Siri 0.6.5"
   HomeKitLink Siri                Finding devices to publish to HomeKit Given Startup...
   Waiting for external plugins to initialize
   HomeKitLink Siri                Starting accessory HomeKitLink Bridge 285967 on address 10.0.1.15, port 51826.
   Starting triggers and schedules
Oct 27, 2023 at 11:40:07 AM
   HomeKitLink Siri                A total of 87 devices are currently selected to be published to HomeKit
   HomeKitLink Siri                87 Home Kit Accessories are now Started.
Ronnie
