Control Chamberlain PD512 Garage Door Opener?
Wed Jan 10, 2018 12:47 pm
ckeyes888 offline
Long shot I know but was hoping someone might have hacked one of the Liftmaster Security 2.0 type openers
so that a momentary switch, i.e. Insteon Garage Module, could operate it?
I tried soldering leads to the supplied push button wall controller with no luck...maybe just suck at fine soldering.
Carl
Wed Jan 10, 2018 5:26 pm
Re: Control Chamberlain PD512 Garage Door Opener?
Should just be able to wire parallel to the Red & White connectors on the door opener according to manual.
Wed Jan 10, 2018 6:11 pm
ckeyes888 offline
Yea, that’s what they told me before I bought it, wanting to confirm I’d be able to control it
with a momentary switch.....but no go.
It definitely requires a specific code not a contact closure.
I have a couple simple switches on order that claim to work with Security 2.0.
Hope I can solder some leads on it.
Carl
Tue Oct 23, 2018 9:37 am
dnomode offline
Did you ever figure this out?
I also have a garage door with security 2.0
Ed
Sat Oct 27, 2018 1:31 pm
dnomode offline
If you just want to control the door, why not use a MyQ gateway? There is no subscription and there is a plugin for Indigo.
I was using the MyQ gateway and the MyQ plugin (which works great). However I cant disable the beeping sound every time the garage door closes using the plugin.
I ended up hacking a Chamberlain 3-button wireless remote control. I soldered 2 sets of wires (one for each garage) to the back of the 3-button wireless remote control and connected the other ends of the wires to two I/O-Lincs.
Screenshot 2018-10-27 15.25.24.png (377.12 KiB) Viewed 1807 times
Works perfectly.
Edmond
Sat Oct 27, 2018 4:08 pm
That's true. It does the same thing if you use the MyQ app to close a door. It's a safety feature. You should be sure you really want to circumvent designed safety features.
Sun Oct 28, 2018 9:12 am
dnomode offline
The beeping and flashing light are great safety features. However the beeping gets old fast when using a Keypad Linc to open and close the garage doors. We don’t really close the garage doors when we aren’t in the garage, however I think I’m going to add something like this as a safety for when we close the door remotely.
https://www.amazon.com/dp/B0153U9ZAW/re ... 1Bb0SRAGM3
Thanks for the idea guys.
Edmond
