Battery status as a device
Wed Nov 15, 2017 2:15 pm
MortenB offline
Hi everyone.
Back at using Indigo after two years of testing other software.
What is the best way to display the batterystatus of z-wave devices as a separate virtual device?
I want to use it in Node Red as well as having it in Indigo.
//Morten
Mac Mini with Indigo 6 - Testing Indigo 7
18 Qubino dimmers
6 Fibaro dimmers (v2)
13 Fibaro Smoke Sensors
13 HeatIt floor thermostats
Also running Node Red and OpenHab2
Thu Nov 16, 2017 11:01 am
Re: Battery status as a device
I don't know anything about Node Red, but can you get it to look at variable values? That would seem to be the path of least resistance.
Thu Nov 16, 2017 12:12 pm
Different Computers offline
Somebody on here posted an amazing python script that automatically compiles every battery operated device into a graphic. It even dynamically updates when you add a new battery device!
SmartThings refugee, so happy to be on Indigo. 10.12.6 on an i5 MBP w/Harmony Hub, Hue, DomoPad, Dynamic URL, Device Extensions, HomeKit Bridge, MatplotLib, Plex, uniFAP, Wunderground, Nanoleaf, LED Simple Effects, Airfoil Pro, Grafana.
Fri Nov 17, 2017 1:18 am
MortenB offline
Well.. For NR to reach the value, I need to publish it trough MQTT so I need to get the battery-status into an "element" that is supported by one of the two MQTT plugins for Indigo.
18 Qubino dimmers
Fri Nov 17, 2017 6:38 am
You might be referring to this script, but I'm not sure that meets the OP's needs. (And thanks for the kind words!)
Fri Nov 17, 2017 7:05 am
MortenB offline
Even if this is not what I'm looking for in this post, I will look into the script as I need an overview of all my batteries :)
18 Qubino dimmers
Fri Nov 17, 2017 8:58 am
That is in fact the script I use, up above. It's awesome!
