Best Door/Window Sensor for Indigo?
Sat Sep 16, 2017 3:47 am
biswasg offline
Four of my Fibaro Door/Window sensors stopped working after the first battery change at the end of the first year or so.
Various attempts at reviving them with fresh batteries to try the inclusion/exclusion process have been fruitless. I have decided to replace them with new ones.
I am looking for advice based on actual usage experience for non-Fibaro Door/Window sensor compatible with Indigo.
I would prefer
1. Long battery life or rechargeable and easy replacement of batteries
2. Small size
3. Preferably also report on temperature
4. Good value for money.
Sat Sep 16, 2017 4:52 am
Re: Best Door/Window Sensor for Indigo?
You will get mixed reports on the Sensative Strips window/door sensor, but my experience with them has been good. I found the device difficult to sync with Indigo (this is due to the device and not Indigo itself). But once it was successfully included, it has been operating flawlessly and still reports 100% battery life (I don't recall exactly when I installed it, but it might be 5 or 6 months ago). Obviously, it doesn't report temperature.
I have a Fibaro window/door sensor that goes through a set of batteries every 2 weeks and I'm planning to take it out (permanently) today. In this particular case, I won't replace it and will rely on the MyQ Door Opener plugin.
Sat Sep 16, 2017 5:08 am
biswasg offline
Thanks for your reply. Incidentally, I have a Sensative Strip. I never managed to include it in my previous Vera network, but it was a breeze including in the Indigo network. Unfortunately, I lost the small magnet strip which is supposed to be placed agains the sensor for closing the loop. I believe any adhesive magnetic strip will work. Yes, the battery status is still 100%.
I am intrigued and interested with your MyQ Door Opener plugin (without a sensor!). I could not find it in your list of plugins. Still in development, I guess.
Sat Sep 16, 2017 5:41 am
That's one of FlyingDiver's plugins: viewforum.php?f=214
It works with select garage door openers from Chamberlain.
Sat Sep 16, 2017 9:12 am
Chamberlain, Liftmaster, some Craftsman.
Sat Sep 16, 2017 10:12 am
+1 on the MyQ plugin - I love it. Add a sensor for instant open/closed status and it's great.
My one little nit: I wouldn't have implemented it as a lock device since I think it's more door-like than lock-like, but that's just an implementation detail.
Sat Sep 16, 2017 11:05 am
Submit a feature request via Github. I'll change it as soon as Indigo has an open/close device ;)
Sat Sep 16, 2017 11:20 am
:D Yeah, we definitely have plans to add open/close sensors (input only: door/window, etc.) as well as open/close actionable types (window coverings, garage doors, etc.). Some of the work is done, but not enough to enable it.
Sat Sep 16, 2017 11:59 am
It's there - and called a relay device. Supports both binary status AND actions to change that binary status... :lol:
Sat Sep 16, 2017 12:09 pm
So is an open door "on" or "off"?
Sat Sep 16, 2017 1:59 pm
on=open, off=closed (that's how door sensors do it anyway). So, from a security perspective, ON means bad, OFF means good. For the UI one can use the uiValue to make it open/close/whatever.
Not perfect and we do want to make it better, but the pattern has been there for a long time in Indigo so people are likely somewhat used to it.
Sat Sep 16, 2017 3:55 pm
I use Adapters plugin to turn On/Off to Open/Closed or vice versa as desired.
Sun Sep 17, 2017 12:33 am
Sevilsivle offline
Same issue with shutters.
It can get confusing as they also have only an on/off state.
On/Off - Open/Closed - Up/Down
