Heater fan with indigo control
Sun Sep 03, 2017 1:03 am
noel1983 offline
Hi all,
Preparing for autumn and winter in my home office and looking for a fan for both heating and cooling.
Naturally I'd prefer to be able to have some control through indigo so wondered if anyone has any recommendations on a fan/heater to buy and how to control.
I like the look of the Dyson's but they're quite pricey and not sure if they'd be controllable.
Cheers
Noel
Not sure if this is quite in the right place so apologies if not
Mon Sep 04, 2017 9:42 am
Re: Heater fan with indigo control
Not directly Indigo but if you're using homebridge someone wrote a plugin for the dysons:
https://www.npmjs.com/package/homebridge-dyson-link
the fact it exists and appears to work suggests some smart sod would be able to reverse engineer its code and build a plugin for indigo.
Alternatively the simple solution would be just standard plugin fans with a z-wave or whatever on/off switch suitable for the wattage load. Of course that offers no additional controls beyond on off. I suppose you could install a dual-relay module if the fan's wiring would allow it to turn on two stages.. perhaps one for on/off and one for heat/no heat.. but be careful of load!
Mon Oct 02, 2017 1:53 pm
noel1983 offline
Thanks for the tip I am tempted for the Dyson’s but they are seriously pricey!!
Mon Oct 02, 2017 3:36 pm
They are! Dyson stuff always is.. I wonder how much their electric car is cost.. and if it’s gonna suck or blow :D
Tue Oct 03, 2017 10:59 am
mat offline
Some of the dysons are IR controllable I believe. The nice upright fan comes with a little IR remote.
mini 10.11.6
Tue Oct 03, 2017 3:40 pm
It’s a shame the Dyson’s have safety built-in; they default to off so you can’t use a third-party plug timer or HA module to turn it on/off - it always powers on to Off state.
Mum got two or three around but I can’t automate them.
Tue Oct 03, 2017 3:45 pm
noel1983 offline
I’ve pushed the button on a ‘normal’ £60 fan heater from Amazon, has a remote control but I’m hoping when power is restored it comes on to previous setting. That way I’ll just use a TKB remote socket that’s tied into indigo and Amazon’s echos which will hit the spot. If it doesn’t turn on with power then I’ll possibly go uber cheap and basic to get one that does! Thanks all
Tue Oct 03, 2017 4:19 pm
@howartp ouch. I assume they’re the non app connected models?
Wed Oct 04, 2017 12:10 am
Correct.
AM05 and AM09 I think.
Can’t see the other one so it might not be Dyson.
Wed Oct 04, 2017 12:46 pm
mat offline
Yep, the fan defaults to off and I couldn't justify an ir module just for the fan!
mini 10.11.6
