Setting Parameters on Qubino 1d flush relay?
Sat May 27, 2017 11:19 am
jester321 offline
Im new to wave and Indigo so could be a total newb question..... I have installed the qubino relay and it works well but I don't want it to respond to the All On command. I know I need to change parameter 10 within the module but I cannot find anywhere in the Indigo software to allow me to change the value.
Any help appreciated.
Sat May 27, 2017 11:53 am
CliveS online
Re: Setting Parameters on Qubino 1d flush relay?
Go to Interfaces > Z-Wave > Modify Configuration Parameter, pick the Qubino 1d flush relay from the Device dropdown and put 10 in Param Index box. Read current value from device to setup the correct byte size for the Param Size and then change it to your value in the Param Value and then Save New Value and close.
CliveS
CliveS
Indigo 7.1.1 : Mac mini Server (Mid 2011) : MacOS Sierra 10.12.6
Sun May 28, 2017 4:24 am
jester321 offline
CliveS - you're a star! Thanks for the pointer.
