Ecolink motion sensor not working
Thu Apr 04, 2019 5:33 pm
michaelu offline
Re: Ecolink motion sensor not working
Just wanted to keep this thread alive, I just got one of these on Amazon and did a return swap thinking it was bad, same results with the replacement.
Found this thread.
This is still not supported, but it is still out there. Hope it makes it into future releases.
Fri Apr 05, 2019 8:30 am
You should be able to get it working using the Trigger for the raw command (steps here).
Sun May 12, 2019 4:07 pm
Indigo 7.3 (and 7.3.1) are now available and should support the Ecolink Motion Sensors (PIR-ZWAVE2 and PIR-ZWAVE2.5).
Tue Sep 03, 2019 10:44 pm
bjmouton offline
I have six of these sensors and they are giving me fits trying to keep them communicating, device state often says "needs re-sync". Triggers for these devices are setup for "Z-Wave Command Received" (which was a work-around to get them to work in an earlier version of Indigo), v7.3.1 did not fix it, in fact they were working acceptably in earlier version and are completely unreliable in v7.3.1
Screen Shot 2019-09-03 at 23.23.06.png (139.33 KiB) Viewed 269 times
Screen Shot 2019-09-03 at 23.32.18.png (25.82 KiB) Viewed 269 times
Wed Sep 04, 2019 12:45 am
Dual offline
Select the device
Select Edit...
Select Define and Sync...
Wed Sep 04, 2019 5:05 am
bjmouton offline
Seriously! With a device state status of "needs re-sync", that is the first thing I tried. Does not work, times out trying to reach device.
Wed Sep 04, 2019 7:26 am
Dual offline
Did you “wake” the device when re-syncing it? Devices have different ways to do that. For example my HomeSeer water sensors require me to push the button once. OTOH with my Haozee motion sensors I push the button repeatedly frenetically.
